Uses for Xylene
Forum topic by McFly posted 03-29-2017 01:07 PM 718 views 0 times favorited 13 replies Add to Favorites Watch
View McFly's profile
McFly
273 posts in 1053 days
03-29-2017 01:07 PM
Any value to xylene other than as a solvent for cleanup? I have a can of it and was wondering if it might work as a thinning agent for spraying clear coat poly.
13 replies so far
View GR8HUNTER's profile
GR8HUNTER
4007 posts in 739 days
#1 posted 03-29-2017 01:55 PM
yes it would work …however the drying time would be increased …better solvent would be lacquer thinner …. IMO …..GOOD LUCK :<))
McFly
#2 posted 03-29-2017 01:59 PM
- GR8HUNTER
I normally do use lacquer thinner for clear coat, but if it won’t have any adverse effects other than an extended dry time, I might try using it on a few pieces of scrap to see how it goes.
View jbay's profile
jbay
2342 posts in 925 days
#3 posted 03-29-2017 02:45 PM
Lacquer Thinner for Poly?
McFly
#4 posted 03-29-2017 02:50 PM
- jbay
LOL. I had to re-read the entire thread wondering wjat the heck you were taking about before I realized I had mistakenly added poly to the OP.
No, the clear coat I use is Sherwyn Williams Sher-Wood LOVOC nitrocellulose lacquer.
View jbay's profile
jbay
#5 posted 03-29-2017 02:56 PM
- jbay
- McFly
You should step up to the SW Sher-Wood T77 F58 pre-cat lacquer.
You’ll never use nitrocellulose again. :)
McFly
#6 posted 03-29-2017 03:31 PM
- jbay
- McFly
You ll never use nitrocellulose again. :)
- jbay
I’ll have to see if I can get a sample from our shwerwyn Williams rep.
woodbutcherbynight
4859 posts in 2435 days
#7 posted 03-29-2017 03:37 PM
Okay perhaps I have not had enough coffee yet this morning. Where does one get this Sher-Wood T77 F58 pre-cat lacquer? I pulled up Sherman Williams local store site and cut and pasted this into it, nothing…. LOL Or maybe they are afraid to sell lacquer to the locals in my area? LOL
View Wildwood's profile
Wildwood
2322 posts in 2161 days
#8 posted 03-29-2017 04:09 PM
Can you use xylene to thin oil based poly? Yes but might want to read this article first. Xylene is more toxic than either mineral spirits or naphtha! Both mineral spirits & naphtha contain a little xylene in it! Lacquer thinner may also contain some xylene.
http://www.popularwoodworking.com/article/A_Primer_on_Solvents
I would be worried about getting the right mix of thinner to poly to lay down a good coat that is durable. Better to use the mixing instructions for product you are using.
Cannot use xylene for water based poly!
-- Bill
View Woodknack's profile (online now)
Woodknack
11793 posts in 2406 days
#9 posted 03-29-2017 04:29 PM
We used a lot of xylene in printing in the 90s, mixed 50/50 with acetone. Alone it takes a very long time to dry. Matter of fact we kept a big open tub of xylene for cleaning and it never evaporated. I would definitely experiment before using it on a project.
McFly
#10 posted 03-29-2017 07:44 PM
- Rick M
I never experiment on a workpiece. Always scrap first to see how it goes.
Been burned before, so never again.
View Kazooman's profile
Kazooman
1030 posts in 1978 days
#11 posted 03-29-2017 08:05 PM
If all else fails, pour it in your gas tank. It is about 115+ octane.
View jmos's profile
jmos
839 posts in 2396 days
#12 posted 03-30-2017 12:14 AM
Xylene is a great solvent, but it is highly carcinogenic. I supervised a unit in a refinery where we made it; heavy duty personal protective equipment required, including supplied air full face respirator. I would not play with it. Benzene or toluene either.
The workers used to try to get out of wearing the PPE because it was inconvenient, and they didn’t seem to believe they needed it. Then they would reminisce about all the old timers that died from rare cancers.
-- John
View jbay's profile
jbay
#13 posted 03-30-2017 01:09 AM
- woodbutcherbynight
Sherwin Williams should have it. Local branches don’t carry it where I live, I go to their industrial branch.
This is it, maybe you could print it and take it to them if needed.
https://www.paintdocs.com/docs/webPDF.jsp?SITEID=STORECAT&lang=E&doctype=PDS&prodno=T77F57
