Old woodworking plates
Forum topic by LDO2802 posted 03-28-2017 08:42 PM 453 views 0 times favorited 2 replies Add to Favorites Watch
View LDO2802's profile
LDO2802
161 posts in 516 days
03-28-2017 08:42 PM
Does anyone know if there is a company that will remake woodworking serial plates? I am restoring a planer and the only thing that looks dingy are the plates. I would like them to look nice for the restoration.
2 replies so far
View MrUnix's profile
MrUnix
6848 posts in 2285 days
#1 posted 03-28-2017 11:01 PM
Check the VintageMachinery Wiki for a good source of machine badge restoration information… from re-painting to making your own using a color printer and decal paper (wet transfer stuff you soak in water). They also have a rather large collection of vintage decal images to use, or you can make your own.
For Example:
If you want to make your own, but don’t have an image – In many cases, you can take a high-resolution photo of the badge, throw it into a graphics package (I use Gimp mostly) to clean it up, and then re-print. Here is one I did for the wiring diagram on a vintage 1954 Boice Crane badged motor made by Oak Electric, with Billy the Safety Alien holding the original that was on the machine, and the reproduction I made from it:
As you can see, the original was well past gone and could hardly be read.
PS: Obviously, if it’s a black and white badge, you don’t need a color printer :)
LDO2802
#2 posted 03-29-2017 01:18 AM
Thank you!
