It's taking me too long to sharpen my plane irons
« back to Hand Tools forum
Forum topic by JohnnyBoy1981 posted 03-28-2017 06:38 PM 2400 views 1 time favorited 51 replies Add to Favorites Watch
View JohnnyBoy1981's profile
JohnnyBoy1981
223 posts in 434 days
03-28-2017 06:38 PM
Topic tags/keywords: sharpen sharpening
Hi,
New to woodworking here, and very new to hand planes. I bought a couple off eBay that I’ve gotten into good working order, and I purchased a new Stanley SweetHeart with the A2 iron.
It takes me forever to get these irons sharp! I’m using some DMT Diamond bench stones, and a Veritas Mk II honing jig.
Getting the backs of the planes reliably flat has, in most cases, taken me hours. When doing the primary bevels, I get the burr on the back so I know I’m removing metal, but I can’t seem to get these things sharp in a decent amount of time to actually go work on a project!
It’s frustrating.
I did buy a DMT extra extra coarse stone in the hopes I can speed up initial bevel formation and back flattening. I also purchased an el cheapo 3000/8000 grit water stone on Amazon.
I don’t want to spend more money on sharpening stuff, but with limited free time, I was thinking about getting the Work Sharp WS3000. Something where I can just fire it up, sharpen/hone my iron and go. Maybe I’m being impatient as a novice…
Any advice on what I might be doing wrong, or what I could do differently? Some other type of equipment that might work faster for me?
Thanks,
John
51 replies so far
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15349 posts in 2615 days
#1 posted 03-28-2017 06:45 PM
John, frustration in sharpening is normal, but hours is not. Maybe recap what you’re doing.
- Are you applying water to the DMTs?
- When first applied to the DMT, what are you seeing on the back of the irons? Perfect flat on the whole thing is not required; flat on the leading edge is what’s mandatory.
- Are you using the extra coarse and it’s still slow, or is that stone still on the way?
- How long does it take to get the primary bevel?
- Proceeding through the grits from there shouldn’t take more than 20 minutes.
Let us know.
View JayT's profile
JayT
5626 posts in 2208 days
#2 posted 03-28-2017 07:25 PM
Once you have the basic equipment, sharpening is no longer about those. Any system (oil stones, water stones, scary sharp, diamond plate or machines) can get planes and chisels sharp and all can fail to get them sharp, as well, if not used correctly. It sounds like you have enough equipment to get you going, so then it boils down to technique, process and habits.
A couple things to add to Smitty’s points.
  • Flattening backs can take a while, depending on how out they were and what grits you start on
  • Once the back is flat (at least the 1/2in or so by the cutting edge) you don’t have to do it again
  • A2 steel is a bear to sharpen, but does hold an edge for quite a while. It’s a trade-off vs O1. O1 is easier to sharpen, but you will be sharpening more often.
  • Is there someone in your area that can help. Maybe a sharpening demo at a local Woodcraft store or something?
You are definitely not alone in the frustration. At my last woodworker’s guild meeting, one of the guys brought up sharpening as something they would like to learn better and about half the group started nodding their heads. Next thing you know, I look over at the guy sitting next to me and he is writing my name down to do a sharpening presentation at next month’s meeting!
Smitty_Cabinetshop
#3 posted 03-28-2017 07:30 PM
Here’s a snippet from a blog entry showing the back of my No. 78’s iron. I stopped flattening at picture time.
First step was to check the iron. I bought the plane probably more than a year ago and my sharpening skills have improved since then, so it was a natural place to start because “sharp fixes everything” and I’m going to be cutting across the grain… The back had to be flattened, but fortunately for me it was concave in the right way. A bit of work through the DMTs had it looking a bit weird, but good.
View Aj2's profile
Aj2
1387 posts in 1795 days
#4 posted 03-28-2017 07:48 PM
It seems like we have thousand different ways to sharpen keep trying you’ll find a setup that works for you.
Some of my projects I spend as much time sharpening as I do with the plane in my hands. But it’s a whole new side of woodworking when you build something start to finish without using sandpaper.
-- Aj
JohnnyBoy1981
#5 posted 03-28-2017 07:49 PM
Thanks for the replies!
My current DMT stones are extra coarse (they consider it to be like a 220 grit which I never thought was coarse), a coarse, a fine, and an extra fine (1200 grit). I ordered their Extra Extra coarse which is supposed to be like a 120 grit. That will get here Friday.
I spritz water on the stones, rub them back and forth until I get a gray swarth, wipe them with an old rag, and repeat. When they stay grayish, I use a Hi Polymer eraser on the stone surface to clean them up (I saw Tommy Mack do that and it works).
All the irons have a primary bevel of about 25 degrees. Since they’re new to me, I thought I’d​ clean up the bevel and flatten the backs.
With the back, I only flatten about 1/4” back. On the corners, on all irons, I have spots that don’t look like they’ve been touched! And when I use my jig, often times a new primary bevel begins to form, and it’s often not straight either. I keep checking the jig but it all looks fine…
JohnnyBoy1981
#6 posted 03-28-2017 09:31 PM
It seems like we have thousand different ways to sharpen keep trying you ll find a setup that works for you.
Some of my projects I spend as much time sharpening as I do with the plane in my hands. But it s a whole new side of woodworking when you build something start to finish without using sandpaper.
- Aj2
Exactly why I started looking into hand planes. I’m making a little end table out of 2×4’s (did I mention I’m a beginner?) and I sanded the top and bottom of the table top. It was noisy, dusty, time-consuming and tedious. I wondered what woodworkers did prior to sanders, and voila! Here I am!
View JayT's profile
JayT
#7 posted 03-28-2017 09:44 PM
Most of us plane lovers have a similar story. The nice part is that the first time you get everything working right, hear that “shhhhhick” of a well tuned plane, see gossamer shavings and the surface that results, you’ll be hooked.
Can you take some close up pics of the cutting edge of the irons (front and back) and post them? That may help people identify something that could going on and how to help.
View Woodknack's profile
Woodknack
11619 posts in 2377 days
#8 posted 03-28-2017 09:45 PM
I flatten things on 80 grit sandpaper glued to my tablesaw wing, then when it’s flat, polish to whatever level I want. My way only takes minutes.
View ErichK's profile
ErichK
80 posts in 660 days
#9 posted 03-28-2017 09:46 PM
I went through a similar path to you. I started with “scary sharp” followed by trying to use some stones, and flattening/setting bevels took FOREVER. I never really got plane irons/chisels sharp enough, because I would just give up before they were done.
SO, I grabbed a Worksharp 3000. I spent an evening sharpening my chisels and plane irons, and was done! I now have VERY sharp chisels and plane irons.
I personally have a feeling that if you start with an iron that already has a good primary bevel, you can sharpen it in 10 minutes like many seem to. However, if you’re like me and put your collection together with vintage store finds and ebay junk, setting that primary bevel would otherwise be a MASSIVE undertaking.
That said, with the Worksharp you will go through A LOT of coarse sandpaper. Setting primary bevels on some of my blades would go through the lower grits at a 1:1 ratio. Prepare to spend a ton of money on coarse paper when you’re getting started!
View ksSlim's profile
ksSlim
1276 posts in 2887 days
#10 posted 03-28-2017 10:06 PM
If you are using DMT plates, might try half water and half Simple green. This mixture prevents “rust” on the plates.
Steel particles left on the plates will appear as rust in 24 hours.
Abrasive materials are denoted differently in different country they are not the same.
DMT plates are rated in microns (1 micron = .001mm).
120 grit in the US is not the same as 120 grit in Briton or elsewhere.
-- Sawdust and shavings are therapeutic
JohnnyBoy1981
#11 posted 03-28-2017 10:15 PM
I will try the diluted Simple Green. I noticed one of the stones had what appeared to be rust on it which I didn’t think was possible so soon.
I had also heard of a person who used Windex with his diamond stones. Same reason?
View Aj2's profile
Aj2
#12 posted 03-28-2017 10:19 PM
I would like to suggest that you don’t try to handplane a surface that has been touched with sandpaper.
Sometimes the grit from the paper will drop down in the pore.Its a hassle trying to plane wood with sand in it.And very frustrating.
-- Aj
View ColonelTravis's profile
ColonelTravis
1768 posts in 1891 days
#13 posted 03-28-2017 11:16 PM
I’ve also got an extra coarse DMT stone, use it primarily for flattening water stones. Every now and then I’ll use it on a bevel, but if a back needs a lot of work I do not start with that. It would take forever. I start with 60 grit sandpaper stuck to a piece of polished granite. Then 80 or 120, then the DMT stone, then the 1K water stone. This should not take hours, or one hour, or even half an hour.
I’m not a fan of diamond stones. The only reason I own one is for flattening. I know some people hate the work/mess of water stones but I don’t mind, and the fast sharpening makes up for it. Again, this is just me. Everyone has their system and you do what’s best for you.
When it comes to flattening backs – I hate it! Not a strong dislike. It’s a real hate. That’s why I start at 60 grit sandpaper. Get this crap over with.
Good luck, keep trying methods. You’ll get it.
View waho6o9's profile (online now)
waho6o9
8189 posts in 2574 days
#14 posted 03-28-2017 11:47 PM
Atoma plates
DMT eh, I love Atoma plates more
Japanese water stones ( a Nagura stone creates a slurry on 6K & 8K stones)
Then strop with Green honing compound and lately I’ve been finishing with a polishing compound Flexcut Gold
The results should be a razor edge in the first picture. Process should be quick.
Funny but true:
Thanks for the Laugh Colonel Travis
View rwe2156's profile
rwe2156
2925 posts in 1478 days
#15 posted 03-29-2017 12:41 AM
From reading your OP I think you should determine whether you have some blades there that are not the best quality or have been mistreated in some way. I’ve bought old Stanley planes with blades that were so warped they were basically unusable. This can be determined quite easily by observing the scratch pattern. If the bottom of the blade is convex, its a hopeless situation. I’ve heard reports of talented people using strategically placed hits with a peen hammer to correct, but I’ve never tried this.
If this is the case, you may want to give some thought to a iron/cap upgrade such as Veritas, or even WoodRiver. You will also find a thicker iron is much easier to register on the stone due to the wider bevel surface.
So on the sharpening in general, if you’re getting a burr you are on the right track. I would recommend you abandon honing on the primary bevel and hone to a secondary (or micro) bevel instead. This will do two things: decrease your honing time immensely & create a stronger edge. It is quite easy to do, just find the primary bevel and pick up a degree or so. I hollow grind all my irons and chisels I find this makes sharpening easier, too.
The most likely issue with a beginner doing freehand is technique. One of those is not locking the wrists and “un” sharpening what’s already sharp due do variations in the honing angle.
You may want to consider a simple jig (I recommend the Eclipse=type) to get you started and create some muscle memory.
You also need to keep the waterstones perfectly flat. You can use your XX coarse diamond plate for this.
Finally, I always finish my honing with 10-12 moderately firm strokes on a leather strop.
In no time at all, you’ll be doing quite well. With practice you will be able to rehone and be back to work in less than 2 minutes.
Hope this helps.
showing 1 through 15 of 51 replies
