tite bond 2 vs 3
« back to Joinery forum
Forum topic by buckbuster31 posted 03-28-2017 05:23 PM 1016 views 0 times favorited 5 replies Add to Favorites Watch
View buckbuster31's profile
buckbuster31
255 posts in 750 days
03-28-2017 05:23 PM
Are there any advantages to using 3 over 2 other than its waterproof capabilities. I will continue to use titebond 3 on cutting boards but I was wondering for general purposes? The reason im asking, at my local hardware it is half price to get the 2 over the 3
5 replies so far
View Marn64's profile
Marn64
296 posts in 1020 days
#1 posted 03-28-2017 05:27 PM
Titebond 3 can creep. I accidentally used Titebond III on my first guitar and barely dodged a bullet because none of my joints were under stress and therefore are safe from creeping. If you are doing outdoor chairs or such than it is fine, but it is definitely an outdoor glue and I prefer titebond 1, titebond 2, and hide glue on my instruments and general woodworking.
-- Benjamin, Milwaukee
buckbuster31
#2 posted 03-28-2017 05:51 PM
you like titebond 2 better than 3?
View darinS's profile
darinS
714 posts in 3102 days
#3 posted 03-28-2017 05:54 PM
According to this ( http://www.titebond.com/news_article/13-05-01/Understanding_the_Big_Three.aspx ) you have a little longer open time with III. Don’t know if that will play into anything for you or not.
-- Rule 40 - If it seems like someone's out to get you, they are.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#4 posted 03-28-2017 06:12 PM
I like TBII best.
TBIII would be better for outdoor projects, or something that may accidentally get run through the dishwasher (like cutting boards). TBIII works at lower temperatures.
I select TBII because of the way it works, and the seamless look you get at joint lines.
I had a TBIII joint turn dark once or twice on oak. That turned me off to using it on oak. It looks good on walnut though.
View bondogaposis's profile
bondogaposis
5148 posts in 2586 days
#5 posted 03-28-2017 07:12 PM
Longer open time and waterproof is the advantage of TB III over TB II.
-- Bondo Gaposis
