Anyone use Lock Miter bit . . . arg
Forum topic by Zuki posted 293 days ago 292 views 0 times favorited 11 replies Add to Favorites
View Zuki's profile
Zuki
925 posts in 605 days
293 days ago
Topic tags/keywords: pricecutter zuki lock miter
DW gave me a couple of sets of router bits several years ago and one of them contained a Lock Miter bit.
By its design it will “lock” a joint together . . . BUT . . . you have to get it set up correctly. One Saturday I spent about 3 hours playing with the bit and got nowhere . . . I was frustrated !!!!!
I just popped over to Pricecutter and saw these:
http://pricecutter.com/2-piece-lock-miter-kwik-block-sets/p/486-1837/
Anyone use them before???
View Russel's profile
Russel
1307 posts in 467 days
293 days ago
I’ve been looking for those. I’ve seen them before, but they were sold with the bit and I already have one. In theory it should make using a rather sensitive bit a lot easier to use. But, a wise man said, “In theory there’s no difference between practice and theory, however in practice …”
I may just order a couple … a $20 experiment doesn’t seem too much if I can use the bit reliably.
View gizmodyne's profile
gizmodyne
1479 posts in 618 days
293 days ago
You would need to have the same exact profile as the bit. Is it the same?
Russel
293 days ago
Well Mr. Gizmodyne, you just had to quash my excitement by stating some fact like it might not match. Now, I’m all depressed. ;-) That’s a really good point though.
View Zuki's profile
Zuki
293 days ago
ya giz, never thought about that
darn
View Don Kondra 's profile
Don Kondra
51 posts in 414 days
293 days ago
Your experience sounds a lot like mine the first time :)
Once you get it right you can save your test cuts and your money…..
The second time around goes much faster and for certain applications is worth it.
Cheers, Don
-- Don Kondra - Furniture Designer/Maker
View GaryK's profile
GaryK
8541 posts in 516 days
293 days ago
Zuki – I would think that you would start low and inch it up little by little until it’s right.
Then as Don says, when it’s right cut a sample piece for setting up the next time.
View motthunter's profile
motthunter
1229 posts in 327 days
293 days ago
They are tricky, but Don is right. After you get it right once, keep a sample for future set ups. Remember that the thickness of the board may change the setup though.
You need to be able to make small micro adjustments in your router table to make it work. These bits require extreme precision.
cut both pieces and compare them. Next split the difference by half and adjust accordingly.
-- making sawdust....
View rikkor's profile
rikkor
8362 posts in 403 days
293 days ago
This has been on my list of tools to acquire. I hadn’t thought about trickiness of set-up.
-- Maplewood, MN
View Tim Pursell's profile
Tim Pursell
217 posts in 310 days
293 days ago
I’ve used these bits quite a lot. Stock thickness is the key. The blocks you can buy to help set up the router table are only good for the EXACT same thickness of stock. Make sure you have more than enough stock thicknessed to finish your project & I usually run some cheaper wood or scraps thru the planner at the same time. Fiddle with the bit height & fence position untll you get the fit you want usiing the scrap pieces. then run all your fine stock. Just be sure to keep some pieces of well fitting scrap & mark the thickness. The next time you need to make the joint you will have little or no set up time – - – AS LONG AS YOU USE THE SAME THICKNESS STOCK - – - I’ve got 4 diff block sets that pretty much eliminates the hours spent setting up the router table.
I know this won’t help you set up the first time, but know that others have fought the same fight & it will be easier the next time!
Tim
-- http://www.grandprairiewoodworks.com
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
293 days ago
Go to woodshopdemos.com. John Lucas has a great method of setting these and it works every time. I’ve used it a lot.
View YorkshireStewart's profile
YorkshireStewart
652 posts in 429 days
292 days ago
I used this type of cutter on my comp entry Oak Box, and used the science of muddling through to set it up. Afterwards, I discovered this that look as as if it might work well. I like Tim’s idea.
-- Res severa verum gaudium - True pleasure is a serious business.
Bookmark And Share This Page
