Drill Press Quill wander
Forum topic by BobinSachse posted 03-28-2017 02:52 PM 413 views 0 times favorited 7 replies Add to Favorites Watch
View BobinSachse's profile
BobinSachse
31 posts in 1478 days
03-28-2017 02:52 PM
Topic tags/keywords: drill press run out
I have a Hitachi floor model drill press (don’t recall the model # right now), but I have been trying to get it lined up again after it being moved twice by clumsy knucklehead movers…
I removed the morse taper quill and cleaned it up. I drove the pin that aligns the table into the post. When I put a dial indicator a piece of steel from my Acu-Rite set in the chuck and turn the drive wheel, it turns about .004” out.
What are your thoughts on this tiny bit of run out? I typically don’t drill things deeper than 3” or so (Pen blanks).
-- Bob Y.
7 replies so far
View Rrrandy's profile
Rrrandy
212 posts in 507 days
#1 posted 03-29-2017 09:04 PM
1/256 isn’t much wander…unless you’re building a rocket ship. What are you making?
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
BobinSachse
#2 posted 03-29-2017 09:36 PM
I’m no Rocket Surgeon…. In the past, I had problems with this drill press drilling straight in a pen blank. But now that I got the centering pin set correctly, my hope is that i will see better results. Just looking for opinions.
1/256 isn t much wander…unless you re building a rocket ship. What are you making?
- Rrrandy
-- Bob Y.
View teejk02's profile
teejk02
481 posts in 1153 days
#3 posted 03-29-2017 09:53 PM
I’ve owned 2 Delta’s and concluded that I will never get to pin-point accuracy on a relatively cheap machine (nor did I ever expect to). Brad point bits maybe?
teejk02
#4 posted 03-29-2017 09:53 PM
Removing a “dupe”...
BobinSachse
#5 posted 03-29-2017 10:19 PM
haha!! You’re quite right, twice!! Sub $200 over 10 years ago, isn’t gonna build any rockets…
I ve owned 2 Delta s and concluded that I will never get to pin-point accuracy on a relatively cheap machine (nor did I ever expect to). Brad point bits maybe?
- teejk02
-- Bob Y.
teejk02
#6 posted 03-29-2017 10:27 PM
looks like a “dupe day”
teejk02
#7 posted 03-29-2017 11:11 PM
haha!! You re quite right, twice!! Sub $200 over 10 years ago, isn t gonna build any rockets…
- teejk02
- BobinSachse
Thanks for the “dupe” notice! Fixed it (I think). Always amazes me on what people expect from our relatively cheap machines. I see a lot of posts about being able to balance a nickel on a table saw or band-saw…how much time does that take? And in the final analysis, does it matter?
