Would this work for a DC
Forum topic by SurfHunter posted 03-27-2017 09:34 PM 812 views 0 times favorited 12 replies Add to Favorites Watch
View SurfHunter's profile
SurfHunter
54 posts in 2609 days
03-27-2017 09:34 PM
changes coming
-- It’s not the hours you put in, but what you put into the hours that count.
12 replies so far
View dhazelton's profile
dhazelton
2790 posts in 2493 days
#1 posted 03-27-2017 09:42 PM
You could make it work for an air cleaner no problem. Someone who has done or attempted to do what you ask will undoubtedly chime in.
SurfHunter
#2 posted 03-27-2017 09:46 PM
sorry pictures are inverted, tried to rotate, but didn’t work for some reason.
View Woodknack's profile
Woodknack
12426 posts in 2576 days
#3 posted 03-28-2017 04:48 PM
Irfanview
SurfHunter
#4 posted 03-28-2017 05:01 PM
Think the pictures were too large, and that’s how the program loaded it. I did resize with Irfanview though.
Thanks
View LDO2802's profile
LDO2802
167 posts in 627 days
#5 posted 03-28-2017 05:23 PM
I would be worried about what the fan is made of if you are going to make it in to a dust collector. If they are too flimsy, an errant screw could really do some damage to it. I agree it could be made into a an air cleaner though. I have an old 1hp Grizzly dust collector, whose name is ironic because it collects shavings, but the dust seems to get away from it. LOL
View Loren's profile
10477 posts in 3844 days
#6 posted 03-28-2017 06:02 PM
steel fans can spark. I think dust collector
fans are made from aluminum alloys.
SurfHunter
#7 posted 03-28-2017 07:20 PM
This is a Cast Aluminum fan and housing.
https://www.amazon.com/Carlson-American-AF-10-R10527-Pressure-Blower/dp/B00R8F0J6U
EATURES
Split housing for maintenance ease
Spark Resistant cast aluminum housing
Spark Resistant Aluminum Wheel
Blower Wheel both statically and dynamically balanced
Rustproof
Base Mount or Flange Mounted Configurations
Choice of Radial, Backward Curved, or Forward Curved Wheel Types
dhazelton
#8 posted 03-28-2017 07:30 PM
This is similar and you can see it is made for fumes and dust. IF you hook this up to an efficient cyclone like a Dusty Deputy it may work, but I’m not familiar with how many CFMs a dust collector requires.
View bigblockyeti's profile
bigblockyeti
5282 posts in 1917 days
#9 posted 03-28-2017 08:01 PM
Looks like it has the power and size to run comparably to a 1hp Delta or JET. It would be imperative to keep any large chunks from making there way to the fan so a cyclone or thein separator would be needed upstream. My 1hp Delta has a steel impeller and housing but everything goes through the fan so the parts exposed to a potentially severe impact need to be malleable enough to reduce the chance of something inside fracturing and turning into a projectile.
View Mainiac Matt 's profile
Mainiac Matt
8546 posts in 2525 days
#10 posted 03-28-2017 08:13 PM
I think it would work well as either a single or two stage. Don’t use a floor sweep and put a course screen on the inlet like metal lathe to prevent large knots.
Single stage DCs are still very much in use out there with metal or aluminum impellors, but the onus is on you to not run metal or knots through it.
Look on e-bay for metal cyclone shells, as there used to be a guy making them for sale.
That and a nice size pleated filter might just do the trick.
-- I yam what I yam and that's all what I yam
SurfHunter
#11 posted 03-28-2017 08:17 PM
yes that is very similar, I believe my blower is rated for up to 20hp motor which is nice.
Like I mentioned, it sure would be be if I were able to put her to use, I was thinking the Quality of it alone may be a big benefit. I picked it up for $5 along with about 50’ of Kanaflex 150CL hose.
from a whse that was liquidating
bigblockyeti
#12 posted 03-28-2017 09:56 PM
Matt, I was thinking of making my own cyclone for a 2hp blower from another dust collector I found for a steal. I did some digging on eBay and found seller Eastcaroga that had a few different steel cyclone for sale, is that the guy you were referring to?
