Router Table: Dust collection?
Forum topic by DaveH posted 664 days ago 373 views 0 times favorited 6 replies Add to Favorites Watch
View DaveH's profile
DaveH
372 posts in 677 days
664 days ago
Topic tags/keywords: router dust dust collection
Does anyone have an idea on capturing the dust when making a cut that is not next to the fence? I’m thinking maybe a dust collection port/slot that is off the left end of the table.
See project:
http://lumberjocks.com/projects/4711
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View Alin Dobra's profile
Alin Dobra
316 posts in 787 days
664 days ago
Dave,
Here I what I do on my router table (your design more or less): I run the dust collection to the router enclosure only (my DS system sucks 650 cfm) and block the entry with a piece of plywood cut to size. The vacuum is strong enough to keep the piece of plywood in place and all the air is sucked through the hole in the top plate around the router bit. I found that this removes all the fine dust and most of the debris to the point that I never bothered with anything. On your setup, you might want to block the air to the fence somehow.
Alin
-- -- Alin Dobra, Gainesville, Florida
View Woodchuck1957's profile
Woodchuck1957
950 posts in 663 days
658 days ago
Dave, the Oak Park Vacu-Plate router table insert has a couple retangular holes in it for dust collection. I think I understand where you are comeing from. I have the same fence and router plate that you are useing, but theres no way I’m going to cut a hole out in the Woodpeckers plate, if I did though, I think I’d take it to someone with a Waterjet or a CNC machine. The table top maybe I’d cut a hole in if I new the hole wouldn’t be too far away that it wouldn’t work well, Sounds like a tough call. Now you got me scratchin my head. How are you likeing the Woodpeckers plate and Freud fence ? I bought the 8 pc ringset for the plate also. Router table top
DaveH
658 days ago
Thanks for the feed back. I’ll have to think about a slot in the table. It might just work. I don’t think I will do a slot in the plate because it may weaken the plate.
I’m thinking the fence system was a bad purchase for me. It’s a little short for the 4 foot table I built and there are no T-Tracks to attach accessories to. I made the purchase because I liked the idea of being able to adjust the left and right side fences independently but I’ll rarely use that feature. I’m probably going to build my own fence.
View Joey's profile
Joey
259 posts in 714 days
658 days ago
My cabinet is pretty close to yours. What i did was buy a dust port from woodcraft and mounted it to the back of the cabinet. My motor enclosure is sealed, not completly but pretty well. most of the time i keep the dust port covered and use the one on the fence. but when using a straight bit or spiral bit, i use the port and it does very well.
-- Joey, Magee, Ms http://woodnwaresms.com
View rikkor's profile
rikkor
11335 posts in 773 days
657 days ago
My system just uses a shop-vac, so it is imperfect. I guess I am used to having to clean up afterwards.
View tpastore's profile
tpastore
90 posts in 715 days
657 days ago
Not the cheapest solution but works pretty well…...
“Locline 2.5 rigid vacuum lines
Get it here
