I am looking to replace my 12" Dewalt DW715 non slider and would like to try a 10" non slider. This will be perminately attached to my miter station for shop use only, making only 90 degree cuts. Is the 10" Dewalt the most accurate? I build cabinet doors for a living and absolutely depend on my 90's being perfect. Not looking for Festool and it seems that Bosch doesn't even make a 10" non slider any more. The 10" Dewalt is available for $219 at Home Depot. Any other suggestions?
I believe the exactness you might be looking for will only be found in the upper shelf units, such as the Milwaukee 2734-20, ($500 bucks), and the Festool.
Hitachi makes the C10FCE2 which plays to good reviews, and is only about $100, but there are a fair amount of reconditioned ones out there for sale, which tells me that some percentage go back.
I don't think you would consider a Craftsman, especially now that Sears might fold, and brands like the Skil to me would be similar to buying a HF. (Although the 10" HF unit has been out there for years and they have sold thousands, although I would be the first to say that they take a half a day to set up properly.)
I bought the 715 before Christmas for $179 and i have found it to be surprisingly accurate. A 10 inch miter has no place in my shop anymore. Combining the words accurate and miter saw on a woodworking forum will bring many opinions
I would go with the dewalt. I have had great luck with dewalt miter saws. If you mount it to your bench, get it dialed in just right and never change it you'll be as accurate as you need. Make sure you get a really good blade, something full kerf so it doesn't deflect.
I own the Dewalt 12" but for portability I bought a cheaper 10" (brand escapes me…Chinese made I'm sure). Maybe just me but there is something about blade travel and safety that makes me prefer the bigger saw. Blades are more expensive of course.
I own the Dewalt 12" but for portability I bought a cheaper 10" (brand escapes me…Chinese made I m sure). Maybe just me but there is something about blade travel and safety that makes me prefer the bigger saw. Blades are more expensive of course.
I actually prefer a 10" over anything else. The blades are cheaper and more readily available and the blade spins faster on a 10" versus a 12" which I like better.
Most of the 10" miter saws can be made to work well, but if accuracy is of the ultimate importance to you, a good TS has better potential for accuracy due to the more robust construction of the mechanisms.
- teejk02
My preference for the larger saw is that on many things the cut is completed long before the motor housing reaches bottom of travel. Maybe my hands are claustrophobic?
My 12" Dewalt is getting pretty worn out, and for some reason I can't get it to stay accurate. The fence has some play in it, and I have to adjust it for square every few weeks. The brake isn't working as it should as the blade keeps spinning long after I let go of the trigger. Among other things, I just want something that is 100% accurate and reliable for straight 90* cuts.
I have a 15" Hitachi and while it's not the size you're looking for, it cuts perfect every time. It does not cut compound miters, only straight miters, absence of hardware that is designed to give another axis of movement helps this tremendously, along with a good table clamp and precise detents. Many older 10" Makita's with cast iron bases where extremely accurate due to this same design principle (and sheer mass). The fewer features you have, the less you have that needs to be adjusted to maintain accuracy.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
