Poplar drawer sides
Forum topic by ric53 posted 03-26-2017 01:24 PM 592 views 0 times favorited 6 replies Add to Favorites Watch
View ric53's profile
ric53
194 posts in 1571 days
03-26-2017 01:24 PM
I use poplar for 90% of my secondary wood in my projects but having a bunch of small pieces laying around I got to wondering if they could be used for drawer sides. I’m talking about desk drawers that would be 1/2” thick. Any thoughts on wood movement. I do not use mechanical drawer slides. Any thoughts on this?
-- Ric, Mazomanie
View IndianaWoodworker's profile
IndianaWoodworker
25 posts in 1701 days
#1 posted 03-26-2017 02:36 PM
Take a look at these to get an idea of the movement of various wood species.
This chart shows the movement in a twelve inch wide board at various moisture contents, included is a formula if your region gets above 9% MC.
http://workshoppages.com/WS/Articles/Wood-Movement-Charts.pdf
This map shows the MC extremes for different regions of the U.S. Use the heavy line closest to your location.
http://workshoppages.com/WS/Articles/USDA-Moisture-Maps-Interior-Woodwork.pdf
When you’re talking wood movement, there are simply too many variables involved…i.e. what wood will you use for the drawer face, back and bottom, what is the fit of the drawers, is the wood quartersawn or flatsawn, etc…to give a simple blanket answer to that question. Add to that the fact that where you’re located makes a huge difference: wood movement isn’t nearly as big of an issue in Arizona as it will be in my home state of Indiana.
Hope this helps you out.
-- Measure twice, cut once?!? But, cutting is more fun than measuring!
5013 posts in 2545 days
#2 posted 03-26-2017 02:53 PM
I’ve used 1/2” poplar for quite a few drawers, and while they were a few problem with it, it’s never been with wood movement. Being a little softer than most hardwoods, it wears some on the slide. It’s sometimes will have a splinter that can snag fine fabrics (like panty hose) so I generally finish it with some shellac, and then smooth that. Otherwise I’d say you’re good to go.
View splintergroup's profile
splintergroup
2146 posts in 1274 days
#3 posted 03-26-2017 03:10 PM
Poplar is quite stable, albeit a bit soft for wear surfaces.
In the event you plan on the drawer being opened up a lot, you could add a wear surface. If the drawer slides on its base, glue on a thin strip of maple or other “hard” wood to the wear edge. If the drawer uses a side bar as a glide, you can dado in a wide piece of secondary wear wood, then dado in a narrower slot to fit the runner.
ric53
#4 posted 03-26-2017 04:46 PM
Thanks for the feedback guys
-- Ric, Mazomanie
View bonesbr549's profile
bonesbr549
1564 posts in 3119 days
#5 posted 03-26-2017 06:50 PM
Poplar will work fine. Use it when someone don’t want to pay for maple. Will it wear quicker, yea, but it will be around a long long long time after you and I are worm bait.
View ArtMann's profile
ArtMann
969 posts in 868 days
#6 posted 03-26-2017 07:41 PM
I would say that poplar is the single most popular wood used in the interior construction of fine furniture. It is certainly true of the furniture in my house, some of which is quite nice.
