My Makita 2030N back on the buy or swap Market
Forum topic by pontic posted 03-25-2017 10:04 PM 662 views 0 times favorited 6 replies Add to Favorites Watch
View pontic's profile
pontic
634 posts in 781 days
03-25-2017 10:04 PM
I have a ‘87vintage Makita 2030N with extra set of blades for both jointer and planer. I have the original tool kit and sharpening gage. I recently rerubbered the rollers. It has it’s own mobile base and dustcollector tubes set up for it.
It runs great and the depth indicator on the planer is still accurate. I was going to sell it to my Nephew but he disappointed me so no deal there. I’m thinking 500 bucks and you pick it up or trade for a good dovetailing jig. I post pictrures if any one is interested.
-- Illigitimii non carburundum sum
pontic
#1 posted 03-26-2017 02:25 AM
View eflanders's profile
eflanders
312 posts in 2023 days
#2 posted 03-26-2017 03:30 PM
Can you please provide some specs? Is it wired for 110 or 220 volt? Is the motor dual voltage? What are the widths for the jointer and planer? What is the overall length of the jointer bed? What is the overall height and weight?
View MrUnix's profile
MrUnix
7004 posts in 2371 days
#3 posted 03-26-2017 03:41 PM
I can help a bit with that… here are the specs from the manual:
It’s not a dual voltage motor – it’s a universal brushed motor. I’m not 100% sure, but it should be like the 2030 (which I have two of) where you could either purchase it with a 120v or a 240v motor, but it won’t do both.
pontic
#4 posted 03-26-2017 11:09 PM
Thanks Brad. Yes it’s 120 volts universal brushed motor.
I lost the Manual a long time ago. It weighs 385pounds as you see it. It has a 6”bed jointer and a 12.5” planer the planer will ro from 5/16” to 6’ the jointer will go from 1/64’ up to 1/8”. On the base it stands about 42” tall. It has about a 48” bed on the jointer.
MrUnix
#5 posted 03-26-2017 11:25 PM
I lost the Manual a long time ago. [...] the planer will ro from 5/16” to 6 [...]
- pontic
Just an FYI – Manual can be found here.
And if you want to plane stuff to thinner than 2mm, you can build a simple auxiliary table to fit over the existing one – a 12” wide laminated shelf board from the BORG works well and will let you go down to 1/4” or less. Anything thinner risks blow-out, but that is typical of all planers and depends on what you are sending through it.
View DocSavage45's profile
DocSavage45
8706 posts in 3015 days
#6 posted 03-27-2017 04:43 AM
Dan,
Too far away LOL! Ive got a good dovetail jig, never used. Did you try craigs’s List? I’ve got both my dust collectors up for sale, but we’ll see?
-- Cau Haus Designs, Thomas J. Tieffenbacher
