Don't Trust Menards S4S
Forum topic by TheDane posted 10-20-2010 08:23 PM 7289 views 0 times favorited 14 replies Add to Favorites Watch
View TheDane's profile
TheDane
5423 posts in 3657 days
10-20-2010 08:23 PM
Topic tags/keywords: tip oak finishing sanding
I made a big mistake a week or so back, and wound up making a mess of a weekend project.
I wanted to knock out some Little Tables like the one Bob A in NJ built … Click for details .
Unfortunately, I didn’t have any 4/4 or 3/4” stock, and the only decent millwork shop in the area keeps hours that would make a banker blush.
I decided to take the easy way, and pick up some S4S Red Oak at Menards … you know, the shrink-wrapped stuff. I bought two 6 foot long 1×10’s, one for each table. According to the store, the face sides are sanded to 180-grit, which AFAIK should be ready for finishing.
The lumber looked fine when I unwrapped it, so I marked and cut the pieces, and did a minimal amount of sanding (after all, this stuff is S4S, which means Surfaced 4 Sides). The 2 tables looked absolutely perfect before I stained them.
My daughter likes dark furniture, so I used MinWax Dark Walnut Gel Stain, which looked fine when I applied it. But when I did the wipe-off, the parts for one of the tables had large areas where the gel stain just did not penetrate. On further inspection, it was obvious that something had been smeared on the board, then wiped off … there was even a distinguishable thumb print! They looked worse than terrible.
I let the gel stain cure for a few days, then sanded it off (thankfully, my drum sander made short work of this), then re-stained the pieces from table #2.
Hindsight is always 20/20 … I should have wiped on some mineral spirits to check the grain appearance, but I normally do that looking for glue stains and since I didn’t use any glue … it never occurred to me that shrink-wrapped S4S stock would exhibit such a problem.
I mentioned this to the manager at the store where I bought the lumber, and though he was sympathetic, said there is nothing they can do once the plastic wrap is off these boards. They get a premium price for this stuff … a little over $7 per board foot.
I won’t be buying any more shrink-wrapped hardwood at Menards.
14 replies so far
View bobkberg's profile
bobkberg
439 posts in 3067 days
#1 posted 10-20-2010 09:15 PM
Thanks for the reminder! I’ve not had that particular experience, but I’ve encountered enough others that it’s a good tip – and a potentially huge labor saver.
One other thought – I’ll bet that no matter what the store manager said, that corporate hq would like to know how they’re irritating customers.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
View Dan's profile
Dan
3630 posts in 2874 days
#2 posted 10-20-2010 10:15 PM
I don’t want to seem out of line at all but is that not to be expected when you buy lumber off the shelf at any store? With the lumber on the racks at the store its right there for anyone to touch. You have to keep in mind that there are many different people from the employees to the customers that are touching the wood. Even though its S4S and very expensive I think a good sanding and close inspection is still a must. I also use mineral spirits but I make sure to apply on everything before I finish. Not just to make spots stand out but to clean any dust or dirt off before I apply the finish.
-- Dan - "Collector of Hand Planes"
View popmandude's profile
popmandude
109 posts in 3014 days
#3 posted 10-20-2010 10:23 PM
I have had the exact same experience. Another problem I have had with big box lumber is when running it through my table saw it puts a death grip on my splitter a bit too often. Sometimes I wonder if they are selling wood cut from the limbs of trees. This is why I shut down my shop until I could get a planer & joiner an mill my own wood. Sure it coulda been wet wood, but the pucker factor got to me, not to mention the price.
Randy
View NathanAllen's profile
NathanAllen
376 posts in 3138 days
#4 posted 10-20-2010 10:30 PM
Dan,
The challenge though is the Menards S$S is wrapped in plastic off-site, which means the board came in contact with wax at some point during production.
Even given TheDane’s bad experience of the three big box stores in my opinion the Menard’s S4S is consistently the best in terms of quality and appearance. The price is the same as HD and Lowes, but the plastic wrapping does help reduce twist and curve since the moisture content is sealed.
View richgreer's profile
richgreer
4541 posts in 3068 days
#5 posted 10-20-2010 10:47 PM
At the Menards I go to they also sell random oak. It is around the corner and you have to know where it is. It is not wrapped and it is only semi-smooth on 2 sides. It sells for about $2.50/bf. It takes a little more work but, in general, I have had good luck with it.
View dq2's profile
dq2
71 posts in 2798 days
#6 posted 10-20-2010 10:56 PM
I wish we had a Menards in Phoenix. I used to go there all the time when I lived in Minneapolis. Now I am forced into HD or Lowes. That’s why I go to Woodworkers Source, because it’s real wood and only 2 miles from my house.
The only time I use wrapped wood is for shelves. I agree with Rich, the random oak works great and I like to do the extra work anyway. (Something about controlling your own destiny.)
Sorry for the problems, but glad to hear that the final product works.
-- - DQ in Phoenix -
View mafe's profile
mafe
11725 posts in 3083 days
#7 posted 10-20-2010 11:30 PM
What a story!
Best thoughts,
Mads
TheDane
#8 posted 10-20-2010 11:47 PM
Dan—How closely can you inspect a board that is labeled and shrink-wrapped? And once you take the plastic off, the store’s attitude is ‘Sorry … you bought it’.
Rich—Neither of the Menards big boxes here had any random oak in stock.
View Howie's profile
Howie
2656 posts in 2917 days
#9 posted 10-21-2010 12:27 AM
I’m with dq2, wish we had a Menards where I’m at.
Wish I could find some of that “random oak” Richgreer was talking about.
Sorry about your bad experience and rightfully so it agravated you(would have me too) but I still have had better experience at Menards than the other two big box stores.
-- Life is good.
TopamaxSurvivor
18266 posts in 3670 days
#10 posted 10-21-2010 01:33 AM
Thanks for the tip. sorry about yoiur trouble ;-(
TheDane
#11 posted 10-21-2010 01:47 AM
I should add … NOBODY DIED! I was able to finish my project (albeit a week later than I wanted to get it done), and the end result was satisfactory.
The only reason I posted this little rant was to (hopefully) help others avoid making the same mistakes I made.
View chrisstef's profile
chrisstef
17378 posts in 3000 days
#12 posted 10-21-2010 01:59 AM
thanks for the heads up dane … another one to store in the back of the old melon
View mess33's profile
mess33
1 post in 2767 days
#13 posted 10-22-2010 06:08 PM
What it comes down to is that dark stains are very tough to do right but look great if done right. You should not assume anything if you want a great finished result. Dark stains telegraph every potential issue. Red Oak is not to bad but Hard Maple and Soft Maple can be the toughest to work with. Menard’s has the best selection by a long shot.
View Sawmillnc's profile
Sawmillnc
150 posts in 3048 days
#14 posted 10-26-2010 12:07 AM
Find you a local sawyer..or mail order stock for cheaper than you can buy @ the mentioned store for less including shipping.
-- Kyle Edwards, http://www.sawmillnc.com, Iron Station , NC (near Charlotte)
