Best bandsaw blades for puzzle boxes?
Forum topic by Elizabeth posted 10-20-2010 06:03 PM 4501 views 0 times favorited 7 replies Add to Favorites Watch
View Elizabeth's profile
Elizabeth
817 posts in 3020 days
10-20-2010 06:03 PM
Hi all,
I have a 14” Grizzly bandsaw and so far only have the stock “blade”. The length specs for this model are 92.5 to 93.5 inches.
I want to get into making bandsaw boxes, puzzles and things like that, so I’ll need to make clean cuts and have a modicum of rotational ability. I want to order some new bandsaw blades for this purpose. I may also do some resawing at times but that won’t be the primary use.
Can anyone suggest some good blades and widths for this usage? I have heard good things about Timber Wolf and Highland Woodslicers but haven’t seen anything in action and don’t know what widths to get anyway.
Thanks!
7 replies so far
View PCTNWV's profile
PCTNWV
99 posts in 2681 days
#1 posted 10-20-2010 06:24 PM
For most I use a 1/8” blade (sometimes a 3/16” for larger items). The blades I use are Carter AccuRight and do a great job. I have a Woodslicer (for re-sawing) and I have heard great things about TimberWolf (a buddy of mine uses them). What i have found makes the greatest difference is the Carter Stabilizer. I have made boxes w/ and w/o the stabilizer and after using it I would not do it again w/o one.
Good Luck and enjoy!
-- Troy, Virginia
Elizabeth
#2 posted 10-20-2010 06:56 PM
Thanks Troy! I looked at the Carter site for stabilizers (http://www.carterproducts.com/product_list.asp?cat_id=14) and they specify one for the 16” Grizzly but not 14”. My saw has kind of a stabilizer (see http://cdn4.grizzly.com/pics/jpeg500/g/g0555_det2.jpg ) but it doesn’t look as good as the Carter one.
Do you know which Carter stabilizer I would need to use?
PCTNWV
#3 posted 10-20-2010 07:09 PM
I have a similar set of guides on my Craftsman bandsaw. I cannot tell for sure which one would fit. I bought mine from: http://www.allbandsawblades.com/ (no affiliation just a satisfied customer)
I would suggest giving them a call as they are very helpful and I am sure they can point you in the right direction.
Thanks.
-- Troy, Virginia
View dendhep's profile
dendhep
5 posts in 2129 days
#4 posted 02-13-2013 07:14 PM
When going with 1/8” blade or 3/16” blade, what TPI do you go with?
View Surfside's profile
Surfside
3389 posts in 2050 days
#5 posted 02-13-2013 10:20 PM
More TPI give a smoother but slower cut
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View Wildwood's profile
Wildwood
2208 posts in 2011 days
#6 posted 02-13-2013 10:56 PM
Not sure if still true, at one time folk with G0555 were taking off bearing guide set-up and replacing with cool block set up from G0580 model Grizzly bandsaw to run ¼” and smaller blades. They bought parts from Grizzly.
Perhaps someone has more info, or e-mail grizzly for some advice. Specs for both BS say 1/4” blade is smallest can run.
JMHO, cool block better guides for using smaller blades than bearings.
-- Bill
View Paul Stoops's profile
Paul Stoops
346 posts in 2438 days
#7 posted 02-15-2013 05:04 AM
I just recently bought a Carter Stabilizer for my G0555X on Ebay, but I see that item is no longer available.The model STD 1 fits the Grizzly 14” bandsaws. If you are not in a hurry, you might check Ebay frequently to see if they show up again. I paid $50 for mine—they list at $80. Good luck!
-- Paul, Auburn, WA
