| Forum topic by Woodstock | posted 946 days ago | 5166 views | 2 times favorited | 15 replies | ![]() |
946 days ago |
Topic tags/keywords: question tablesaw I’m looking for suggestions for an aftermarket fence for my Bosh 4100 table saw. I’m looking for this with a few levels of “wants” depending what ideas / suggestions I can gather from here. What I’ve got: Choice #1: Get a true Biesemeyer fence system. I’ve read enough reviews that this seems to be the best way to go for aftermarket fences. Except I can’t decipher which (if any) model would fit. Choice #2 Get some sort of Biesemeyer Fence clone IF it is made for my model & will bolt on directly or with very minor retrofitting / drilling to the table top. Choice #3 Adapt another model fence for a “Brand-X tablesaw” to retrofit the 4100. (Lest favorite option. But may be my only option.) Does anyone have any suggestion? (Besides buying another brand T/S.) -Dave -- I'm not old. Just "well seasoned". |
15 replies so far
#1 posted 946 days ago |
I’m actually surprised that you want an aftermarket fence! I have a 4100 and am really quite pleased with the fence. The only thing I’d like to change about it is the length; I wish it started a few inches earlier. Even if I found a better fence, I would probably be annoyed that I couldn’t stash it in that dedicated fence-storage spot while I use my crosscut sled. FWIW, I wouldn’t recommend another table saw. I know everybody bashes on the portables (and they have their downsides, I agree), but I very very rarely feel like it’s holding me back. I can absolutely do 0.001” level work with no more effort than I’d need on a bigger/better saw. The downsides are mostly noise and handling of long and/or wide pieces. I did replace the miter gauge with a nice incra. Finally, my shop is 12’x14’... I feel your pain. -- -Michael |
#2 posted 946 days ago |
Make your own maybe… www.twistedknotwoodshop.com/tsquarefence.pdf -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#3 posted 946 days ago |
I’d be concerned that a commercial Biese will weigh enough to upset the balance of the Bosch 4100…it’s possible that the fence and rails weigh as much or more than the saw. I’d also be concerned that the installation could be complicated by the construction materials of the Bosch. You might have better luck with a lighter fence like the Incra, but I’m still unsure how well that fence would mate with the 4100. It might be helpful for all of us to understand what you’re hoping to gain from the fence change. Would it be easier to add some faces or an aux fence over the existing Bosch fence to meet the same objective? -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#4 posted 946 days ago |
Thanks for responding. As usual LJ forums has given me more things to think about in coming up with a workable solution. mstenner: The locking lever mechanism on the stock fence vs. the aftermarket fences I’ve seen on the web leaves a lot to be desired. But I agree it is nice to pop off the stock fence & store it on the side of the saw body when folding up the saw for storage. rance: Now I’d rather spend my time in the shop turning rather then reverse engineering/building something to fit unless the isn’t another viable option already in existence. Too much of my time is spent adapting tooling to making something fit rather than creating turned wood projects. But I’ll keep this .PDF in my back pocket as an option. knotscott: I may give some thought to aux fences that can slip over the stock fence to facilitate additional fixtures. But it still doesn’t help with the repeatability / square / fine adjustments issues of the stock fence. Good suggestion on things to consider everyone. Keep ‘em coming. With you help I’m sure there is a workable solution out there. -Dave -- I'm not old. Just "well seasoned". |
#5 posted 946 days ago |
N6DSW: both of those points are good, and I agree with you. Here’s how I addressed (or mitigated) them: repeatable squareness: I never just push down on the handle. I always push in on the little protrusion below the handle (the thing that’s flush with the handle when the handle is down) and then lock it. In fact, I usually put the heel of my hand on that protrusion and grab the rail from below with my fingers and then squeeze. This makes locking the fence a two-hand operation, but that’s never been a problem (I can do it with a push stick in my hand). This is so automatic now that I had to run downstairs mid-message to to see what it is I actually do. Basically, this forces the reference points to make solid contact before the clamp gets involved. I get absolutely perfect results every time (best I can tell).
micro-adjust: I got a cheap ($10) dial indicator from harbor freight and mounted it to a little 5-minute fixture that I clamp to the rail. It only gets 1” of travel, of course, but I only ever need it when I want to fine-tune a cut. Make cut, measure cut with calipers, then adjust with the dial indicator. The fence doesn’t slide super smoothly so it’s a couple of bumps back and forth. If I do the trick above as I watch the indicator, then it doesn’t move at all when I lock it down.
I’m not trying to convince you or anything :) If this helps you out, great. If not, tell us how you like the new fence! -- -Michael |
#6 posted 833 days ago |
I have a Bosch 4100. Wanted the bennies of a biesemeyer style fence. Went with the Rousseau table saw stand. I love it. |
#7 posted 621 days ago |
I have gravity stand with my saw how do the roussean 2275 attach to bosch tablsaw. |
#8 posted 501 days ago |
I’m “patiently” waiting for my 4100-09 to arrive. I have a large stationary saw with an attached router table built into a cast iron wing and 52” Jet Lock fence. Can’t very well take that to a jobsite. I bought another set of yellow Board Buddies with the mounting rail for the Bosch. I have figured that the tee slot on the face of the Bosch’s fence can be used to attach an auxiliary 3/4” maple “face board” with which to attach the BB aluminium mounting rail to that. That being said if I wish to stow the fence on the saw in its storage slot all I will have to do is remove the aux fence board with the removal of 3 flat head machine screws that will be countersunk into the face of the aux board. There is an “entry point” at the far end of the fence to slide 1/4-20 hex nuts into that tee slot. The slot I’m told “locks” those nuts for tightening. All this leads to the fact that you can “extend” the length for the rip fence if need be. The table extends to 25”. Even with an aux face board of 1/2 or 3/4 you’ll still be able to rip a 4×8 sheet in half. I also ordered the left side table extension bar for it. That attaches the guides with 4 socket head cap screws into bosses cast into underside of the table. There is a set screw knob that locks on a flat side of the bar on the operator side. This gives another 12” of support to the left of the blade. It slides back against the table for stowage. As for the accuracy of the fence, that issue can be resolved with set up adjustments. This is a “jobsite” table saw, not a Bridgeport. If it will keep to 1/64, I’ll be happy. Hey, you need room for glue n’est pas? An Incra miter guide will be in it’s future too I think. As for the 4100-09 I’m waiting to put it through its paces. I “kicked the tires” a bit at a Lowes where they had one on display. That Gravity Rise stand is simply marvelous. It even has pneumatic tires! I may Slime those just for S&G’s so that flats will be a non issue. -- OK, who's the wise guy that shrunk the plywood? |
#9 posted 355 days ago |
I have the 4100. I raved about it in another thread, then two days ago, i went to make sure it was true 90 degrees to the table, and then noticed that when i lock down the handle, the left side slightly “pops” up. Took it apart, tried to find something that is out of whack, but it would still pop up on the left. Nice thing is, the fence has a t-slot on the sides of it, so i’m going to make an auxiliary fence with recessed holes, which can tighten down in the t-slots, and use thin shims between the fence and the aux fence until I get a perfect 90. Not a biggie, as I obtained all the episodes of WoodWorks recently, and David Marks uses an auxiliary fence to, so I will feel cool doing it anyway. OTHER than that though, I love the saw, as I’m in a 10’x20’ one car garage, so it’s nice to easily roll it out into the driveway. -- Ev in Framingham, MA |
#10 posted 350 days ago |
Hi Everett1, My “beloved” factory Bosch fence went south on me a few weeks ago. In doing a autopsy on it I found that there are two el-cheapo plastic “guide pads” on either side of the “T” each held on by two flat head Phillips screws. One of the “pads” was broken off leaving only the two screws behind. If you look at the link from the eReplacementParts.com website they are pictured in the drawing diagram, item #182 on page “A”. P/N 2 610 950 101. (2) each saw fence. http://www.ereplacementparts.com/bosch-4100-0601b13010-table-saw-parts-c-128_167_14496.html and more specifically http://www.ereplacementparts.com/pad-p-200866.html?osCsid=23fk54vs8dh9nqmui7achb5cl0 Very cheaply made, but for $1.37 each, I ordered 6 pieces to lesson the $10.00 shipping charge. I’m still stalking the mail person each day waiting for them to show up. Hope this helps get things squared up. -Dave -- I'm not old. Just "well seasoned". |
#11 posted 96 days ago |
Hello, I realize that this is an older topic, but I wanted to say something about the 4100 fence system anyway. Jef |
#12 posted 96 days ago |
I think shimming is probably the easiest solution for truing up the fence vertically. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#13 posted 96 days ago |
I’m surprised no one has mentioned the delta t2 yet |
#14 posted 96 days ago |
I think I will try this first. http://www.axminster.co.uk/axminster-axminster-rip-fence-upgrade-prod362802/ Jef |
#15 posted 86 days ago |
Hello everyone, The Axminster Fence arrived, and I am sure it is great. But it looks like I won’t be to use my table extension to Jef |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
