Exterior front door (weatherproofing)
Forum topic by Mark Shultz posted 03-24-2017 12:56 PM 563 views 0 times favorited 3 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
109 posts in 2506 days
03-24-2017 12:56 PM
I’ve been planning to make a new exterior front door for my home, to go along with a larger renovation. I have read up on the approaches to making the door, but what I can’t seem to find is much literature or advice on weatherproofing. I know about the aftermarket weatherstripping from companies like Randall, but im more interested in the “integrated” approach, such as with metal interlocking strips that I see on some doors.
Anybody have thoughts or source material to read on weatherproofing a new custom door? And vendors!
Thanks
3 replies so far
View GR8HUNTER's profile
GR8HUNTER
4548 posts in 829 days
#1 posted 03-24-2017 03:27 PM
View jerryminer's profile
jerryminer
942 posts in 1558 days
#2 posted 03-25-2017 09:27 AM
Metal interlocking weatherstripping (in brass or aluminum) still exists, but isn’t used much any more because
A: it is time-consuming (and therefore expensive) to install.
B: It is very unforgiving of slight shifts in the way the door hangs.
C: It requires some special tools
D: It doesn’t seal against air infiltration very well.
Door manufacturers use all kinds of weatherstripping systems, some proprietary. The company I work for generally uses kerf-in Q-lon—which works well but isn’t as “clean” looking as the metal interlock. We have used some of the “vinyl bulb” products that are lower-profile with success.
I would recommend against the interlock, and use something replaceable, like Q-lon or a vinyl bulb. My .02
(You can buy all three options from Pemko and other places)
Mark Shultz
#3 posted 03-28-2017 07:14 PM
thanks guys.
