Making an infill plane, need some references, does anyone have a Norris smoother?
« back to Hand Tools forum
Forum topic by Marn64 posted 03-24-2017 12:37 AM 356 views 0 times favorited 4 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 689 days
03-24-2017 12:37 AM
Topic tags/keywords: question plane
I am making an infill plane, based off of a Norris no 4 plane. Mine is pinned together rather than dovetailed, and thus the sole is 1/2 inches thick. the plane I am making is around 7 inches, I am bedding the iron at 50 degrees. What I am curious about is the blade thickness and the width (or rather how open) the mouth is. Does anyone have a Norris no 4 and are willing to give me measurements?
-- Benjamin, Milwaukee
View Don W's profile
Don W
18604 posts in 2471 days
#1 posted 03-24-2017 02:02 PM
I can’t answer your question directly because I don’t have a norris, but in general, when you build a smoother, the tightness of the mouth is in relationship to how fine you want your shavings to be. When I build a plane, I start with it a little to tight, because it’s easy enough to open it up. It’s a bit problematic closing it though.
Marn64
#2 posted 03-24-2017 04:51 PM
I can t answer your question directly because I don t have a norris, but in general, when you build a smoother, the tightness of the mouth is in relationship to how fine you want your shavings to be. When I build a plane, I start with it a little to tight, because it s easy enough to open it up. It s a bit problematic closing it though.
- Don W
that seems what I am going to do. I am aiming for a 6.3 mm mouth as a starter, meaning that when the blade is level with the sole, the mouth will be about .008 in. opening.
View Just_Iain's profile
Just_Iain
275 posts in 320 days
#3 posted 04-11-2017 06:11 PM
Marn64
#4 posted 04-11-2017 06:31 PM
This might be of help: https://www.toolsforworkingwood.com/store/blog/908/title/Mitre%20Planes%20and%20the%20Finest%20of%20Mouths:%20Why?%20What%20Evidence?%20What%20to%20Look%20for%20When%20Shopping%20for%20Mitre%20and%20Shoulder%20Planes
- Just_Iain
Thanks!
right now my design has a hair widths mouth opening that will be filed open so I can get it just right.
