| Forum topic by dakotawood | posted 946 days ago | 1369 views | 0 times favorited | 16 replies | ![]() |
946 days ago |
Topic tags/keywords: circular saw trim saw I’m in the market for a nice circular saw mainly to help give me one straight edge on sheet goods. I see norm uses that worm drive PC trim saw. It sure appears like it makes a nice cut, but I’m not sure I want to drop $225. What’s everyone’s answers: 1. Circ saw or trim saw? Thanks! -- Travis, South Dakota |
16 replies so far
#1 posted 946 days ago |
I’ve got a worm drive (I think that’s what it is) Makita circular saw. Cut up quite a few boards and sheet goods with it too. Not sure what the model is (I’m at work right now, not at home to check. Looks like a 5277B though). It’s corded, and I really like the little thing. -- Hyperbole is the best thing ever!! |
#2 posted 946 days ago |
+1 on the TS55. Super-clean cuts. Festool just shipped me a MFT/3 to evaluate, looks like it’ll be an amazing combination. -- The Wood Nerd -- http://www.workshopaholic.net |
#3 posted 946 days ago |
I use Milwaukee Tilt-Lock circular saw. For me it is great saw? just put Freud Diablo blade in it and you are in business. To make straight cut use cut guide, that is major guarantee for success, plus good blade, everything else is minor. That is my experience. |
#4 posted 946 days ago |
A third vote for the Festool TS55. If you wanna cut sheet goods, the saw on the rail is awesome. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#5 posted 946 days ago |
A forth vote for the TS55. I bought the MFT/3 table. It makes a great combination. You can do a great deal more than just sheet goods with the two tools together. Look on Festool’s site to see. There was a blog on this site I think that showed you how to make a poor man’s MFT/3 table out of MDF. I think you still need one Festool MFT/3 to get the miter gage and to have the rails to attach jigs but the ability for a versatile bench to assemble large cases etc looks attractive. The TS55 is also about the same price as the Dewalt track saw but I think much higher quality. Domer |
#6 posted 946 days ago |
Travis, I have two cordless saws, Ridgid and DeWalt. I use them interchangeably, depending upon which one has the strongest battery. The cuts do have some chipout but I usually cut them about an inch oversize and true the plywood up on my tablesaw. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#7 posted 946 days ago |
Vote #5 for Festool! -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#8 posted 945 days ago |
I bought the nicest, proudly made in the USA, Skil Saw I could find in 1978; cost about $100 I think. Still purrs like a kitten. Haven’t seen anything comparable in today’s China crap offerings. I guess, if I had to replace it today I would go with a worm drive saw. I also use the foam board for cutting sheet goods with a rip guide. I think the only thing better would be a panel saw. But, to be honest, I never looked at the Festool because it is so expensive. It must be pretty good to have such a loyal following. Of coursre, if I had paid $500 for a circular saw, I’d sing its praises too. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#9 posted 945 days ago |
For occasional use, you don’t need to go high end. Dewalt, Bosch, Makita, etc. Pick your favorite color in the $100 range and go. I think the blade and a good straight edge are the the keys here. If you are doing this every day in a production setting, then by all means invest in production quality gear. I made a simple zero clearance plywood cutting jig out of MDF that I clamp to my cut line, and cut away. From a practical standpoint you couldn’t get a better edge with Festtool. You could set it up quicker, and put less sawdust on your shop floor, and the edge may or may not look better under a microscope, but other than that, the two cuts are indistinguishable. For the 10 sheets or so of plywood that I rip per year, this approach is more than adequate. I generally make my first cut or two on the plywood this way, and then take it to the table saw when it is easy enough to handle there. -- PaulMayer, http://www.vernswoodgoods.com |
#10 posted 945 days ago |
I think you are miisng the most important point…the blade. -- Few folks really know how to maximize the potential of their tools! |
#11 posted 945 days ago |
Another vote for the TS55. There is a DeWalt and Makita version of the same type of saw and they may be just as good – but I have never used one. Expensive but worth it. Used ones are on ebay often. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#12 posted 945 days ago |
I’ve been using a $60 Black and Decker lightweight corded 7” circular saw with an aftermarket blade that probably cost me $25 for the last 15yrs to cut sheet goods down to components-didn’t want to wrestle an 80lb sheet of hardwood ply down 13 stairs to my basement workshop. Been using Clamp & Tool guides (also inexpensive) to ensure straight edges when I cut. To eliminate chipping along the kerfs, just cover the area with blue masking tape, mark your lines, and cut. -- Gerry |
#13 posted 944 days ago |
I just use a Porter Cable MAG (blade on the left side works best for me even though I am right handed)with a good/decent Frued blade and a 50” Borla clamp/Edge guide. Not as fancy as a FesFool but works great for me. -- If at first you don't succeed then maybe skydiving isn't for you. |
#14 posted 944 days ago |
I use a Bosch CS10 corded. I really like way it fits my hand comfortably, if your outside cutting sheet goods, it has a nice hanger on it ,so you don’t have to set it on the ground you can hang it on your saw horse instead. You can also register for a 5yr warranty no charge. -- A poor man has poor way's |
#15 posted 944 days ago |
Skil worm drive and Tenryu blades for the cuts. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
