| Forum topic by Dchip | posted 943 days ago | 793 views | 0 times favorited | 3 replies | ![]() |
943 days ago |
I’m gonna be making a mitered picture frame and I’m try to peg down the best course of action. The frame is going to have a 1/8’’ roundover on inside and outside. Questions: I should roundover the inside before assembly since the inside corners will be a problem with the bearing, right? (Same with the inside rabbet) Should I wait until after assembly to roundover outside so corners are uniform? Any downsides to this? Climb-cut to prevent blowing out the mitered corners? I appreciate input from anyone with experience in this area. Thanks. -- Dan Chiappetta, NYC, http://www.9x7woodworks.com |
