Fixing/hiding a crack??
Forum topic by Belg1960 posted 03-23-2017 04:19 PM 1350 views 0 times favorited 15 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1060 posts in 2970 days
03-23-2017 04:19 PM
Topic tags/keywords: question
Guys, I have a medicine cabinet that has a beveled glass mirror imbedded into the frame with no way to remove it. I want to inlay/fix this somehow so it won’t be seen the crack is about 5/8” in the corner. I’m showing a corner piece I’m playing with but it will not work as the handle on the opposing side will be affected. And inlaying with the curves will be a tough job with the mirror in place. Any thoughts??
-- ***Pat*** Rookie woodworker looking for an education!!!
15 replies so far
116902 posts in 3482 days
#1 posted 03-23-2017 04:43 PM
Hi pat
your idea might work but I would be concerned that the cracks will extended outward in time due to using the door or wood movement. in other material, you can stop cracks by drilling a small hole at the end of the cracks but I’m not sure you can do that on glass.
#2 posted 03-23-2017 04:58 PM
Another idea is to make an inside the frame trim that goes all the way around the Mirror,
This kind of idea
Belg1960
#3 posted 03-23-2017 10:32 PM
Jim, I like the second idea but unfortunately I don’t have the depth to make it work. I’m going to have to recess the solution in the frame of the door somehow.
Belg1960
#4 posted 03-26-2017 11:48 AM
Bump, any ideas would be appreciated.
#5 posted 03-26-2017 03:00 PM
Pat If you used thinner material say 1/4” would it work?
View bigJohninvegas's profile
bigJohninvegas
417 posts in 1367 days
#6 posted 03-26-2017 04:15 PM
If you could get the glass out, could you replace it? Match it? If so, go ahead and break the glass. Get it out of the way. Open the grove on the back side with a router so that the new glass panel will fit. There are many ways to fit the new panel from buying clips, to cutting strips of wood to wedge in the groove.
The links below are just a couple ideas.
http://www.leevalley.com/us/hardware/page.aspx?p=50400&cat=3,40914,50427
http://www.leevalley.com/us/hardware/page.aspx?p=41859&cat=3,40914,50427
-- John
Belg1960
#7 posted 03-27-2017 10:43 AM
Jim, the flat part of the mirror is only about an 1/8” below the face frame.
John, I was hoping to avoid this and also the rear side has a beaded panel over it. So whatever I do will have to be done from the front. Thanks for those links I will definitely keep that in mind for the future.
I did add some 1/4” tubing sections as spacers around the mirror so I think someone must have hit it or kicked it by accident.
Belg1960
#8 posted 07-31-2017 11:26 AM
Guys, this is the solution I came up with!! The client loved it. Sorry for the crappy pic. I used the pattern from the decorated door to replicate an inset piece, made a template for a pattern router bit routed ,glued and used some heavy duty two sided tape . It was a little delicate not to hit the high side of the mirror but got lucky. Thanks to all for your suggestions.
View Aj2's profile
Aj2
1272 posts in 1703 days
#9 posted 07-31-2017 01:09 PM
Bravo I Ilike it !
-- Aj
View LittleShaver's profile
LittleShaver
267 posts in 524 days
#10 posted 07-31-2017 01:32 PM
Very nice. It takes real skill to turn a flaw into a design feature.
-- Sawdust Maker
#11 posted 07-31-2017 01:53 PM
ingenious idea but I’m concerned after some vibration the crack will migrate out beyond the patch.
View Gilley23's profile
Gilley23
488 posts in 287 days
#12 posted 07-31-2017 02:47 PM
First, I would have gotten some of the resin that is used to repair car windshield cracks and injected that into the crack in the mirror. That would have stopped the crack from ever spreading outward.
Your cover-up looks great! Nice craftsmanship.
Belg1960
#13 posted 07-31-2017 07:32 PM
Guys, the crack already ran from corner to corner so I don’t think it will move any further. I appreciate the tip about the resin will tuck that into the memory for hopefully never having to use it again. ;-)
Gilley23
#14 posted 07-31-2017 11:11 PM
Dang man, sorry to hear that!
Guys, the crack already ran from corner to corner so I don t think it will move any further. I appreciate the tip about the resin will tuck that into the memory for hopefully never having to use it again. ;-)
- Belg1960
Belg1960
#15 posted 08-01-2017 01:17 AM
- Belg1960
- Gilley23
Gilley it’s just a small tiny corner like in the original picture in my first post. The medallion covers it very well.
