Sizing Drawer Slides
Forum topic by NewbieInWV posted 03-23-2017 01:09 PM 341 views 0 times favorited 6 replies Add to Favorites Watch
View NewbieInWV's profile
15 posts in 522 days
03-23-2017 01:09 PM
Topic tags/keywords: drawer slides nightstand cantilevered
Hey all,
I’m designing a cantilevered nightstands in Sketchup. Since I have little experience with drawers, I was wondering if I should choose a drawer slide size first, and then design the drawer depth around that.
- or -
Once I’ve designed my nightstand, can I simply purchase the drawer slide that most closely fits what I need?
Here’s the design in-progress:
-- Mike H, Elkins WV
#1 posted 03-23-2017 01:28 PM
Additional info:
The inside dimension from the face front to back is currently 17”.
There is a 1/2” gap between the back of the drawer and the inside back of the cabinet.
I’m leaving a 1/2” gap between the sides of the drawer and the supports for the drawer slide (front supports not shown).
View TungOil's profile
869 posts in 428 days
#2 posted 03-23-2017 01:43 PM
I always design around the slides I intend to use.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Ron Aylor's profile
Ron Aylor
2316 posts in 580 days
#3 posted 03-23-2017 01:50 PM
- TungOil
I agree with TungOil … get the slides first, then  build the drawer around them!
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
View builtinbkyn's profile
2055 posts in 873 days
#4 posted 03-23-2017 01:56 PM
If I read things correctly, it looks like you would use 16” slides. You’ll need to account for them in the width of your drawer.
-- Bill, Yo! Brooklyn & Steel City :)
View Nubsnstubs's profile
1267 posts in 1663 days
#5 posted 03-23-2017 02:25 PM
I’ve never seen slides in any length but even numbers. The width of the drawer is immaterial as far a slides are concerned. Make you drawer width 1 1/16’” smaller than the opening, and if needed, you can shim the difference, or if using Fulterer guides, just use the side adjustment tabs built in to make it a snug fit. ................. Jerry (in Tucson)
-- Jerry (in Tucson)
View JBrow's profile
1340 posts in 853 days
#6 posted 03-23-2017 03:57 PM
I like to have hardware in hand and have a good understanding of the installation instructions before I lock in the dimensions of the carcase, face frame and drawer boxes. The slides you select will likely require a minimum cabinet depth and top, bottom and side clearances.
I also suggest when you get to the point of building drawer boxes that you build one by nailing or screwing together some scrap to represent the drawer box dimensions. I did not do this the first time I used slides from Knapp and Vogt. As a result I now have three solid wood drawer boxes with dovetailed joinery waiting for the right project. I guess I did not completely understand the instructions. I got the dimensions wrong and had to remake the drawers.
