help with 1 RD columbian vise
« back to Hand Tools forum
Forum topic by olcoach posted 03-23-2017 12:35 PM 872 views 0 times favorited 8 replies Add to Favorites Watch
View olcoach's profile
olcoach
11 posts in 562 days
03-23-2017 12:35 PM
I have an old Columbian vise and the only #s etc. I can find is 1 RD other than the company name. The vise appears to be a quick release as the screw has a flat spot with no threads on it. My problem is I can only turn the handle less than a 1/4 turn and it hits a metal protrusion that is part of the casting so obviously meant to be there. There has to be a trick to releasing the mechanism but I can’t find it and there very little info out here on vises. Somewhere there is an old timer that knows the secret. I’m going nuts trying to figure it out and if anyone can solve my dilemma I’ll be so grateful. Thanks, Mike
-- olcoach
8 replies so far
View Johnny7's profile
Johnny7
382 posts in 1210 days
#1 posted 03-23-2017 03:26 PM
photos, my friend, we need photos
View noahm's profile
noahm
10 posts in 676 days
#2 posted 03-23-2017 06:52 PM
This thread may help as he does a teardown on one.
olcoach
#3 posted 03-24-2017 07:03 PM
I will have pictures up tomorrow but I don’t think they will help. What I need is someone that has worked with one of these vises who knows the secret. Somewhere there is an old timer (someone as old as me) that used one of these that he got from dad or grandpa. My vise is in a lot better condition than the vise in the teardown and I tore this one down as it’s pretty easy but it still doesn’t help unlock the secret.
-- olcoach
olcoach
#4 posted 03-25-2017 07:54 PM
Here are the pictures. If you look to the left of the large right hand bolt you can see the flange that prevents the handle from turning. You can also see the metal run down longer on the right side of the tool thus proving that that’s how it’s supposed to be. I know it makes no sense. Someone please help.
-- olcoach
View JayT's profile
JayT
5822 posts in 2331 days
#5 posted 03-25-2017 08:00 PM
The handle on that model should turn 3/4 revolution. Someone took it apart and reassembled it with the nub in the wrong location. Pop the pin out, take those pieces off and reassemble correctly and it should work.
olcoach
#6 posted 03-25-2017 09:43 PM
It does turn 3/4 of a turn but that isn’t going to turn very far. You talk about taking the pin out. I’m not sure where there is a pin-enlighten me please and thanks for your help.
-- olcoach
View JayT's profile
JayT
#7 posted 03-25-2017 10:14 PM
If it’s doing 3/4 of a turn, that’s the design so you shouldn’t need to change anything on this end if the quick release is working correctly. Your original post said it was only going 1/4 turn, so that’s why I thought maybe it had been reassembled incorrectly.
On the quick release styles like that one, they are designed to release with counter clockwise 3/4 turn, then you slide them tight up against the work piece and the 3/4 turn clockwise re-engages the threads and tightens up the work piece. Works pretty fast once you get used to it, but doesn’t allow as much control over the clamping pressure. That’s actually a good thing on a quick release, as too much pressure can break the mechanism.
olcoach
#8 posted 03-26-2017 01:29 AM
Jay T thank you as it makes sense. I thought I was going nuts. Thanks to all who replied. Mike
-- olcoach
