Grizzly G1022Z Extension Wings Question
Forum topic by ohtimberwolf posted 03-22-2017 11:51 AM 405 views 0 times favorited 7 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
750 posts in 2260 days
03-22-2017 11:51 AM
Topic tags/keywords: grizzly 1023z wings table extension
Here is my question. What is the best way to fill in the holes in these table wings? I like the cast iron but I’m not sure I am going to like the holes in my table top.
I thought about turning them over and filling it with a light coat of fiberglass.
Picture is borrowed from SwampDonkey772
Thanks SD.
-- Just a barn cat, now gone to cat heaven.
7 replies so far
View mrg's profile
mrg
804 posts in 2907 days
#1 posted 03-22-2017 12:49 PM
I have seen these wings filled with melamine, mdf etc cut to size and stuck in the holes flush with the top. Probably with a backer board and epoxy.
-- mrg
View knotscott's profile
knotscott
7877 posts in 3283 days
#2 posted 03-22-2017 12:55 PM
I think the easiest thing to do is to ream out the holes on the wings enough so you can drop the wings low enough to attach some 1/8” tempered hard board on top….there may already be enough play in the wing holes to do that. They’ll be well supported by the cast iron grates, and will have the benefit of the mass and rigidity of the cast iron.
ohtimberwolf
#3 posted 03-22-2017 01:27 PM
Thanks MRG new ideas.
Knot – I wondered if that could be done. I’ll check out the holes and see if there is substantial space. Too cold to work in there today so it will have to wait a while.
knotscott
#4 posted 03-22-2017 03:21 PM
Knot – I wondered if that could be done. I ll check out the holes and see if there is substantial space. Too cold to work in there today so it will have to wait a while.
- ohtimberwolf
If not enough room, I wonder if a laminate would work…probably harder to adhere flat to the CI, but I’ve never tried…
ohtimberwolf
#5 posted 03-22-2017 03:59 PM
There are some pretty thin laminates, I will look into that also. Thanks
View Rick_M's profile
Rick_M
11131 posts in 2288 days
#6 posted 03-22-2017 05:36 PM
I have a neighbor that applies laminate over cast iron tops and he likes it.
-- http://thewoodknack.blogspot.com/
ohtimberwolf
#7 posted 03-22-2017 07:51 PM
Thanks Rick, that helps. larry
