Advice on Router Table
Forum topic by RichCMD posted 03-21-2017 11:44 PM 987 views 0 times favorited 17 replies Add to Favorites Watch
View RichCMD's profile
RichCMD
395 posts in 1998 days
03-21-2017 11:44 PM
Topic tags/keywords: router table woodpeckers kreg
I need some advice about the size of the router table compartment that houses the router itself. I am planning to enclose my Woodpeckers router table, which has metal legs, to add dust collection and storage. I have found numerous photos and plans from people who have done this with a Kreg router table, but not a single example for the Woodpecker’s table. I can use the pictures of the Kreg tables for ideas about how to do it, but they are not much help when it comes to measurements.
For reference, my table stand looks like this:
Woodpeckers router table stand
I need advice about how wide to make the center section that contains the router. I would like to have room for drawers (or doors) on either side the center section. I plan to put a 4 inch dust collection port on the back of this center section, and then use a T junction to connect the hose from the router table fence and the 4 inch dust port to my dust collector, so there should be some air flow. I would like to avoid creating overheating problems by making the center section too small, so I am looking for suggestions on how wide it needs to be.
-- Ride the bevel!
17 replies so far
View Kelly's profile
Kelly
2044 posts in 3001 days
#1 posted 03-22-2017 02:47 AM
Obviously, the brand is a non-issue. What it’s really all about is, dealing with two separate matters – dust collection and storage.
I’m running a Bench Dog lift, which holds Porter Cable’s biggest bad boy. This is all mounted on one of my carts, giving me about 2’x4’ of table top [on which sits my Freud fence].
I’d built a more accommodating cart than I could buy, so I figured I might as well build the router cover for dust collection too. In the end, I built a simple box open on one end and the other rounded, to limit dust build up. I used a single piece of some vinyl left over from a bathroom job to cover the bottom.
One side of the cover has a door I can open to access speed, or to just see how things are doing. Of course, the whole base can be lifted out of the table too (with a bit of grunting).
I mounted the lower dust port in the vinyl and it joins to the top via a T.
The Freud had a 2-1/2” pick-up port, but I opted for four inch port on the hosing for the router, even though the whole thing is throttled down by the router plates. It just seemed to make connecting the dust collector easier, so the T joining the two ports has a reducer for the smaller upper area.
I never run the table without dust collection, so, with all that air pulling past the router, it shouldn’t ever have a heating issue.
When it’s all said and done, between the router and cover, most the center is spoken for. A single drawer could be installed across the bottom, but I’d probably opt for shorter center drawers top to bottom and full (24”) depth drawers could be installed right and left of the cover.
In the end, not much gets by the collection for many operations.
If you need them, I can give you dimensions I used for mine tomorrow.
Kelly
#2 posted 03-22-2017 02:57 AM
In the end, if you’re running dust collection, the box shouldn’t have to be that much bigger than is necessary to cover it. All that air moving past a three and a quarter horse (15 amp) router should play the role of a heat sink pretty well.
RichCMD
#3 posted 03-22-2017 06:14 PM
Thanks for you information. This is very helpful.
-- Ride the bevel!
View them700project's profile
them700project
115 posts in 1076 days
#4 posted 03-22-2017 06:33 PM
This is mid project, but it shows better the size of the box I made for collection. This was a jessem masterlift top and there were rails on the bottom side of the table to stiffen the top(I assume). My verticals are just inside the rails and I notched the right side for the lift control shaft.
Kelly
#5 posted 03-22-2017 06:58 PM
I went out and measured the cover I made and took a couple more pictures. Mine could be shortened by ten inches. I wasn’t worried about room and didn’t know how much saw dust would build up inside, so I gave it PLENTY of room. Making it shorter and still running collection, heat should never be a problem, and you can make a bottom drawer about sixteen inches deep and twenty-four inches long (since my table is two feet wide).
I stand corrected on the hose sizes. Both the top and the bottom are 2-1/2. If I made the cover shorter, it would be easy to make the bottom port a four inch one.
My cover measures 20” tall x 12-3/4” square. It shouldn’t be a problem to reduce the twenty inches to twelve.
117160 posts in 3634 days
#6 posted 03-22-2017 08:33 PM
You can save yourself the trouble of enclosing your router by installing this product by keen products. I put one in my side feed table and I now have zero sawdust above or below. It’s hard to beat this for router dust collection.
http://lumberjocks.com/reviews/2703
View Woodchuck2010's profile
Woodchuck2010
707 posts in 915 days
#7 posted 03-22-2017 09:21 PM
I have a woodpecker table frame with a Jessem master fence and built this cabinet with storage and 4” dust collection. It works great!!!! Excuse the last sideways pic.
http://i45.photobucket.com/albums/f90/saturncjc/IMG_4006.jpg!
-- Chuck, Michigan,
View simonov's profile
simonov
62 posts in 563 days
#8 posted 03-22-2017 09:27 PM
You can save yourself the trouble of enclosing your router by installing this product by keen products. I put one in my side feed table and I now have zero sawdust above or below. It s hard to beat this for router dust collection.
If you can find one. The item has been discontinued.
-- Nunc est bibendum.
View JBrow's profile
JBrow
1365 posts in 977 days
#9 posted 03-22-2017 09:29 PM
RichCMD,
My router cabinet is wood construction with a 1-1/2” wide rails and stiles making up the face frame. The overall width (outside to outside) is about 35”. There are narrow drawers on each side of the router compartment. The narrow drawers are on wooden runners and the drawer boxes are from ½” thick plywood. An insert trays set in the narrow drawers and the inserts accommodate 4 router bits in a staggered configuration across the width of the trays. About 1” of width on each side could be saved if the drawer boxes are omitted and bit storage trays with a drawer front (no sides or back) are used instead. Additional space could possibly be had by reducing the width of the stiles.
Hope these dimensions help…
Kelly
#10 posted 03-22-2017 09:40 PM
Now you have me intrigued, but clueless.
- simonov
#11 posted 03-22-2017 10:01 PM
Woodchuck2010
#12 posted 03-22-2017 10:19 PM
I didn’t have much luck with the Keen system. I took it off after a short while and built the cabinet. Much better!
-- Chuck, Michigan,
#13 posted 03-23-2017 04:10 AM
Not sure why it didn’t work for you Chuck but I works great for me.
them700project
#14 posted 03-23-2017 11:55 AM
Something to note. screwing into the top isnt easy. I predrilled and used fat sheetmetal screws. It seemed to work OK. The other thing is you may want to caulk the box. My top drawer fills with sawdust and im not 100%sure where its coming through. I think I will attempt to caulk mine this weekend.
View HokieKen's profile
HokieKen
5702 posts in 1196 days
#15 posted 03-23-2017 12:07 PM
For my cabinet, I built the compartment where the router is housed just big enough to let me access anything I may need to while the router is installed. Then I cut holes in the door kinda like the slots in Woodchucks door. I started with smaller holes and kept enlarging them until I felt like the flow was enough to cool the router and all the dust was collected. With the DC hose disconnected, the holes in the door plus the DC port are enough to allow sufficient cross flow to keep the router cool. I guess my method wasn’t scientific but it worked. Basically make the compartment a convenient size then make sure the dust is sucked out and the router stays cool.
-- Kenny, SW VA, Go Hokies!!!
