New site for Scale modellers
Forum topic by Knappen posted 03-21-2017 05:26 PM 429 views 0 times favorited 2 replies Add to Favorites Watch
View Knappen's profile
Knappen
61 posts in 1900 days
03-21-2017 05:26 PM
Topic tags/keywords: resource
I have now released my new website. i would like to recieve any comments that you have.
Here is the link:
PG-Scale Models
-- Knappen aka Ole - I have to try everything at least once. http://oknap.dk/pg
2 replies so far
View MrRon's profile
MrRon
4764 posts in 3238 days
#1 posted 03-21-2017 06:48 PM
Congratulations on your new endeavor. I wish you all the luck. Your current offerings look very good and the sample drawing shows professionalism. If I may make a suggestion; the dimensions are metric and most in the U.S. use the English system. I realize you would have to redesign your drawings to the English system so others would not have to convert and therefore have to work in decimal dimensions rather than even numbers. For example: a 500mm dimension would convert to 19.685” which no woodworker would ever work to. That dimension would have to be rounded up to 19-11/16”.
Knappen
#2 posted 03-22-2017 04:53 AM
Thanks for the comments.
As to whether it should be metric or imperial I do not think that it will be a big problem for users of the imperial system, as all plans have full scale part drawings, so it will only be holes, shafts and other round parts to be converted.
