Finishing wood that's finished already...
Forum topic by Tommy posted 10-17-2010 10:23 PM 931 views 0 times favorited 2 replies Add to Favorites Watch
View Tommy's profile
Tommy
138 posts in 2705 days
10-17-2010 10:23 PM
I finished a small work piece and used a spray-on gloss poly as my final coat. I’m not happy with the finish and I want to lightly sand the piece and then come over top of my original finish with multiple coats of laquer for a glossy smooth finish. Is this something I can do? Consequences?
Thanks in advance for any help guys!
TK
-- Tommy, ---- It's Never Crowded On the Extra Mile.
2 replies so far
View huff's profile
huff
2828 posts in 3162 days
#1 posted 10-19-2010 02:25 PM
Tommy, I’ve sprayed lacquer over a lot of different finishes before and most of the time it’s worked fine. You difinetly need to lightly sand before you put anything over the gloss finish. (so the new finish has something to adhere to). I would make a sample board first and experiment with that. Most manufacturers don’t recommend mixing finishes. If you’re using a spray lacquer from a can ( like Deft), then I’ve found them to work on almost any surface, but again, I would do a sample board first. How big is your project and is it stained? If it’s stained, be careful not to sand thru the finish and get into the stain. If it’s not a very big project, you may just want to strip it down and start over. I know that sounds like a lot of work (and time), but sometimes that’s the best solution. I’ll be glad to try to help you thru the process, just drop me a line and we can talk about it more. I’m no finishing expert, but over the years, I’ve run into different situations and had to work out a solution. I don’t know about you, but I hate spending all that time building something and then can’t get the finish to look right. Good luck and let me know how things turn out.
-- John @ http://www.thehuffordfurnituregroup.com
Tommy
#2 posted 10-20-2010 02:51 AM
John, thanks for the input. I was hoping it was just like you suggested. The project is small and it’s a gift for my parents. I’ll post some projects here in a few days when I return from vacay. I actually finished some and can finally post (they’re my first few pieces really). I am using a Deft spray, good guess. REALLY appreciate the response, I want my projects to look good but there is just SO much to learn! Tommy
