Epoxy Fill Brand Recommendation
Forum topic by Ray D posted 03-21-2017 12:10 AM 652 views 0 times favorited 8 replies Add to Favorites Watch
View Ray D's profile
Ray D
33 posts in 1365 days
03-21-2017 12:10 AM
Topic tags/keywords: epoxy voids finishes west system systemthree
Hello!
Let me start by saying for some reason I have begun to overthink while making myself crazy and before I make this new purchase I need some guidance.
I’m up in the air about what epoxy to purchase for filling voids. I have used West Systems a while back and it did a nice job. I see many continuing to use it while now I see some using SystemThree. I like the West System process as it’s almost idiot proof with mixing. Looks like SystemThree fills voids as well but has a vast majority of many other types of products/applications/finishes which has their own place.
•West Systems vs. SystemThree?
•Pros vs. cons?
•Tinting?
•Etc.
•Any information or guidance would be greatly appreciated.
Thanks so much!
Ray
-- Ray - Minooka, Illinois
8 replies so far
MrUnix
7005 posts in 2372 days
#1 posted 03-21-2017 12:44 AM
They are all pretty much the same… epoxy is pretty much just epoxy as long as it doesn’t have any fillers in it (like most of the syringe type things you find at the BORG). Some may have slightly less or more viscosity, but they all flow well when neat, and all can be tinted/colored.
PS: I use west system epoxy a lot for filling voids and cracks in wood… and the syringe stuff when I want to glue the sole back on my shoe :)
View Bob5103's profile
Bob5103
101 posts in 1007 days
#2 posted 03-21-2017 01:01 AM
I use West System almost exclusively. Depending on the project I either use 205 or 207 hardener. 205 if the bond is not going to be seen, 207 if I need to tint or have a clear joint. It lasts forever and I really like the pump system. 2 years ago I needed to restore a chainsaw carving of “Bigfoot”. At 7’6” tall and 30” in diameter it is huge. The legs had rotted on the inside, and I needed a way to fill the legs and stop the rot. For that I used Abatron’s Liquid Wood and Wood Epox system. It worked very well, and was easy to use, except I had to use a measuring cup to mix and that was really messy. I tried to tint the Wood Epox, but it was inconsistent and I used the WS 207 for the visible part of the repairs.
I don’t think there is a huge difference between brands, for me it just boils down to what I am used to. Here is “Bigfoot” while waiting for repair:),
View bondogaposis's profile
bondogaposis
5053 posts in 2525 days
#3 posted 03-21-2017 01:17 AM
I have had success with both West System and System 3 T-88. The main difference is in viscosity, West system epoxy is a lot thinner and flows easier. T-88 is much thicker, I think it would be better at gap filling.
-- Bondo Gaposis
View Jim Finn's profile
Jim Finn
2684 posts in 3095 days
#4 posted 03-21-2017 01:34 AM
For small voids I use “Z-poxy” with colored powdered chalk for tint. It is actually a finishing resin and penetrates very well. It is thin and slow to cure.
-- No PHD just a DD214 Website> craftingcouple.com
View John's profile
John
245 posts in 1755 days
#5 posted 03-21-2017 01:45 AM
West systems is very thin, but sometimes I add their filler product to make it thicker for the purpose of filling voids. With a little dye, it looks great.
-- I measured once, cut twice, and its still too short...
runswithscissors
2869 posts in 2199 days
#6 posted 03-21-2017 07:29 AM
Wood flour from a sander is excellent for coloring epoxy. The filled space will be a darker color, however, which could be a problem. I always thicken my epoxy because I think it makes a stronger bond.
View MrRon's profile
MrRon
5137 posts in 3417 days
#7 posted 03-21-2017 07:22 PM
I think you will find many interesting products here; https://www.smooth-on.com/
Ray D
#8 posted 04-02-2017 04:56 PM
Thanks guys! I appreciate all the input!
