glue blocks
« back to Woodturning forum
Forum topic by Karda posted 03-20-2017 06:21 PM 652 views 0 times favorited 6 replies Add to Favorites Watch
View Karda's profile
1006 posts in 490 days
03-20-2017 06:21 PM
is there any special glue for glueing to a face plate or extending a spindal
View TheDane's profile
5385 posts in 3599 days
#1 posted 03-20-2017 06:28 PM
I use Titebond I (original in the bottle with the red label.
Just to be clear, you do not glue directly to the spindle or faceplate.
You use a metal faceplate that is screwed to the wood waste/glue block with #12 sheet metal screws, face off the glue block, then glue your workpiece to the glue block.
View MrUnix's profile
6499 posts in 2135 days
#2 posted 03-20-2017 06:29 PM
For a metal face plate, you use screws. For a wood face plate/glue block, regular PVA glue is fine. Some will additionally put a piece of paper (like from a paper grocery bag) to aid in removal, but I’ve never found that necessary and just part it off as usual.
#3 posted 03-20-2017 06:38 PM
thanks I have watched some UTubes where it is mentioned as an option but they cave no specifics about the glue
View xunil76's profile
31 posts in 401 days
#4 posted 03-23-2017 12:17 PM
from all the videos i’ve watched on woodturning, i’ve noticed that there are typically 3 types of glue used:
1) wood glue (should be pretty evident what this is for…to bond 2 pieces of wood together securely)
2) CA glue (a.k.a., superglue. used primarily to stabilize wood to keep it from chipping/cracking further and fill in cracks/voids while mixed with sawdust)
3) hot glue (mostly used to temporarily glue pieces onto waste blocks for turning when other attachment methods are unavailable)
if you want the best bond to the waste block and don’t mind waiting for it to fully cure, then wood glue between your work piece and the waste block (both properly cleaned & trued-up, mind you) is going to be the best bond.
if you can’t or don’t want to wait for wood glue to cure, then hot glue can be used between your work piece and the waste block, assuming your work piece is not too heavy. this makes it much quicker to get started on your work and much easier to remove the piece when you’re done…BUT….it will never hold as well as wood glue, and has a higher chance of coming off the waste block while you’re turning.
i would never use CA/superglue to hold a piece on a faceplate/wasteblock…that’s not what it was designed for, it won’t hold up to much side-loading while simultaneously supporting the work piece, and it will stay behind on the piece of work when it’s removed. keep CA glue where it’s supposed to be: filling in small cracks/voids and stabilizing punky/cracked wood, or being used as a finish for small things like pens & bottle stoppers.
i’m sure there are other types of glue used, but these are going to be the bulk of what woodturners use on a regular basis
View LeeMills's profile
514 posts in 1237 days
#5 posted 03-23-2017 12:47 PM
For dry to dry .. wood glue (Titebond or other).
For dry to wet (green) it won’t work. Use CA which will set on wet wood.
Look up Lyle Jamieson on youtube for details of using CA. I don’t think he ever uses a chuck at all.
View Nubsnstubs's profile
1267 posts in 1666 days
#6 posted 03-23-2017 02:43 PM
Lyle doesn’t use chucks because they don’t hold…... Jerry (in Tucson)
-- Jerry (in Tucson)
