spakel or silicone?
Forum topic by SuperDave02 posted 10-17-2010 01:20 PM 4897 views 0 times favorited 3 replies Add to Favorites Watch
View SuperDave02's profile
SuperDave02
141 posts in 3199 days
10-17-2010 01:20 PM
I just built some “painted” buillt in book cases around my sliding glass doors, and because the sheetrock is not striaght there are some gaps that are easily seen. If i used silicone at only about a dollar a tube, would it be just as good as if I used the spakel which is over 7 dollars a tube?
Thanks
david
-- David South FLorida http://rockingrrustics.blogspot.com/
3 replies so far
View Howie's profile
Howie
2656 posts in 2891 days
#1 posted 10-17-2010 01:41 PM
The silicone will flex with the seasons. Just be sure it is the paintable type of caulking.
-- Life is good.
View Ger21's profile
Ger21
1074 posts in 3099 days
#2 posted 10-17-2010 03:12 PM
Don’t skimp to save a dollar. By the most expensive (best) paintable caulk you can get. It shouldn’t be more than $4-$5 and should last forever.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
Howie
#3 posted 10-17-2010 05:48 PM
Cessna and Ger21 are correct I should have clarified my statement on silicone. Besides you don’t want it around anything you are finishing.
-- Life is good.
