Anyone have any idea what this wood is?
Forum topic by JBoss posted 945 days ago 695 views 0 times favorited 8 replies Add to Favorites Watch
View JBoss's profile
JBoss
37 posts in 1214 days
945 days ago
Topic tags/keywords: question
I got these boards from habitat for humanity. the dark one is the question, It is some exotic, super hard, and burned my nose when i jointed it. The redish one is bubinga, any ideas on the other?
8 replies so far
View richgreer's profile
richgreer
4474 posts in 1241 days
#1 posted 945 days ago
My first guess is Wenge. When you work with Wenge you find that is quite splintery. That is how you would know for (almost) certain.
View ACP's profile
ACP
28 posts in 1377 days
#2 posted 945 days ago
ipe
richgreer
#3 posted 945 days ago
Ipé is usually not that dark. It could be that this is an abnormally dark piece or the lighting makes it look darker than it is.
Ipé will not float. That is one way to check to see if it is ipé.
Both ipé and wenge are very hard, heavy woods but ipé is harder and heavier.
FYI – unless treated, ipé will get lighter over time.
View pedroadami's profile
pedroadami
2 posts in 945 days
#4 posted 945 days ago
I believe that if it doesn’t float can be Ipe, if it float, can be angico preto (Timbaúba, or Faveira Folha Fina) density = 900 kg/m3
-- Pedro C. Adami
View araldite's profile
araldite
187 posts in 1570 days
#5 posted 945 days ago
Could it be tropical walnut?
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View webwood's profile
webwood
616 posts in 1416 days
#6 posted 945 days ago
peruvian walnut looks much like that
-- -erik & christy-
araldite
#7 posted 945 days ago
I think Tropical and Peruvian walnut are the same thing. They are dark brown with even darker brown streaks through it. I’ve seen it used in flooring but it’s expensive.
JBoss
#8 posted 944 days ago
I was leaning to wenge, as I have heard that it is an irritant to your nasal cavities. This stuff def is, burned my nose even when I jointed a different board as the dust and chips were still in the jointer. According to the people at habit the pile i got that board from is supposed to be all from S. America, but I can’t verify that.
