Glue suggestions for applying a felt box liner
Forum topic by Planeman40 posted 03-19-2017 02:29 PM 1073 views 0 times favorited 10 replies Add to Favorites Watch
View Planeman40's profile
Planeman40
1175 posts in 2754 days
03-19-2017 02:29 PM
Topic tags/keywords: glue
I am working on a display/storage box for a project and will be lining the inside with felt for the protection of the project. It will be a fitted case so there will be small compartments to line. For this reason I would rather be able to brush on the glue rather than use a spray can of Spraymount. I have heard that white glue can be thinned with water and if so this would be preferable. Does anyone out there have any experience or suggestions for this? Any other type of adhesive? The case is rather sizable, 6 ft. x 1 ft. x 7 in.
Planeman
10 replies so far
View Kazooman's profile
Kazooman
1005 posts in 1945 days
#1 posted 03-19-2017 03:24 PM
I have used rubber cement to apply felt to the inside of boxes. It works very well. Another possibility is to use felt with an adhesive backing. One issue I have had with that is that the felt stretches as you remove the paper from the adhesive. You cut it to the proper size, but it ends up stretching and you have to trim the excess off with a razor blade or Xacto knife.
With white glue (thinned or not) I would be concerned that the glue would soak through the felt, ruining the surface.
View pontic's profile
pontic
582 posts in 601 days
#2 posted 03-19-2017 03:44 PM
Why don’t you Flock it on?
-- Illigitimii non carburundum sum
Planeman40
#3 posted 03-19-2017 04:09 PM
Flocking is a thought, however my judgement tells me it wouldn’t give me the padding I am looking for with felt.
View martyoc's profile
martyoc
42 posts in 910 days
#4 posted 03-19-2017 04:17 PM
I made a silverware chest with a felt lining and just used Titebond. It has held up very well for over five years.
-- Marty O'C
View JAAune's profile
JAAune
1796 posts in 2310 days
#5 posted 03-19-2017 06:51 PM
I like to glue the cloth to thin cardboard so I can work with stiff “panels” that can be carefully fit into the openings. Usually I’ll cut the cardboard to the perfect size first then apply cloth, then glue it in the box.
I’ve used full strength white glue for this and it works fine. Too much glue will wet the cloth too much. That’s not an issue since I can toss out the bad glue up and make a new one because the cloth isn’t attached to the box until after it’s stuck on the cardboard.
Planeman40
#6 posted 03-19-2017 09:54 PM
”I like to glue the cloth to thin cardboard so I can work with stiff “panels” that can be carefully fit into the openings.”
Interesting thought! I may try it. Thanks!
I have use Titebond for this before. It works well but is somewhat thick to brush on. I did a test of thinning it with water as it can be cleaned up with water but this destroyed its adhesion ability.
Keep the thoughts coming!
View jeffswildwood's profile (online now)
jeffswildwood
3180 posts in 1970 days
#7 posted 03-19-2017 10:41 PM
I have felted a LOT of boxes. I use titebond II every time. I don’t thin it, use it right out of the bottle. I use a good foam brush to spread it evenly using “just enough”, not too thick or thin. Watch your edges though. I use a home made tool to smooth the felt. Just a small piece of wood rounded over and sanded VERY smooth. Hope this helps.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View Bobsboxes's profile
Bobsboxes
1367 posts in 2657 days
#8 posted 03-19-2017 11:19 PM
I use white glue and a small cutoff to smooth the felt down.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
Planeman40
#9 posted 03-20-2017 03:56 PM
Thanks everybody! I think I will work with Titebond and the cardboard.
View splintergroup's profile
splintergroup
2006 posts in 1215 days
#10 posted 03-20-2017 04:12 PM
I do what JAAune does, larger surfaces get panels. For something the size you are stating, I would typically use 1/8” masonite. The felt is applied with 3M “77” spray then the panel is secured with small pieces of double sided tape.
Smaller areas use cereal box thickness cardboard, same DS tape to secure.
Anytime I have tried to use TB or other wood glue, the bleed-through ruined it in spots. It really is sensitive to the type of fabric being used.
