| Forum topic by CharlieM1958 | posted 295 days ago | 336 views | 0 times favorited | 19 replies | ![]() |
295 days ago |
I use my trusty PC690 for both table-mounted and freehand work. I have a fixed base to leave on the table permanently, and both a plunge base and an extra fixed base for non-table work, so dismounting from the table is not any big deal. I would, however, like to get something with a little more power, as well as variable speed, so I could safely use some of the larger bits that require slower speed. Since I don’t do any sort of production work, I tend to think the 3 1/4 HP Triton might be overkill. I’m wondering if something in the 2 1/4 HP range would suffice, or should I just go ahead and spend another $100 to get the big boy? If you’ve been down this road before, I’d appreciate hearing what you decided and how that choice panned out. -- Charlie M. "Woodworking - patience = firewood" |
295 days ago |
It depends on the size of bits you are going to run. The 2 1/4 will work for most profile bits but if you are planning on making raised panel with cope and stick joints then you really need the Triton. The router has gotten good reviews and looks to be an excellent tool. I use my 690 in one table for edge profiles but for raised panels and larger bits I have a Dewalt 625 in another table. I have seen references to using a smaller router for horizontal panel raising bits but I, for one, would not try it as I think that it would be too hard on the router. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
295 days ago |
I’m kinda leaning to the direction that, if I’m spening money anyway, I might as well be prepared for anything I might want to do. -- Charlie M. "Woodworking - patience = firewood" |
295 days ago |
Get the biggun Charlie! Like you said, might as well be prepared for anything. -- Carl Rast, Pelion, SC |
295 days ago |
Go for the 3-1/4 HP Trtion. That is one sweet router. There is not enough price difference in the two for me not to get the bigger one. Ok, now that I said that, I have two 2-1/4 HP routers, and they are both more than enough power for me, and I even run some panel raising bits every now and then. If I were in your situation, it would be the 3-1/4 HP. Buy the best you can afford or you will regret it. That’s what my dad always said -- -- Rob Hix, King George, VA |
295 days ago |
LOL! I don’t know why I asked. I should have known the LJ concensus would be to go big! -- Charlie M. "Woodworking - patience = firewood" |
295 days ago |
Charlie that is true. A friend of mine, who is a professional woodworker, once advised me to always buy the most expensive tool I could afford. His opinion was that price equates to quality and it is better to get one quality tool than buy two cheap ones. The times that I did not take his advice I have regretted it later. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
295 days ago |
Someday I’m going big, but it will go in the table. The 3-1/4s might be a bit unwieldly for hand use. -- Maplewood, MN |
295 days ago |
Yeah…...That is my plan…..for the big one to pretty much stay in the table. Well, I’ve pretty much made up my mind. Now I have to convince my wallet. -- Charlie M. "Woodworking - patience = firewood" |
295 days ago |
Charlie, you might try the Tool King link on the sidebar of the LJ site. They have really good quality reconditioned tools. I bought a VS PC 690 from them with interchangeable bases and also a Dewalt cordless saw. Their delivery charge is minimal and they have a good selection. They have a PC Variable speed 3 1/4 HP for 279.00 and a Bosch 3.25 HP plunge for 260.00 NEW. You might check them out. I also think woodcraft has the triton on sale right now. Good luck on your buys! God Bless, -- Saving barnwood from the scrapyards |
295 days ago |
Charlie M, I have 3 690’s . One is permanently mounted in a table for my dovetails. I had another one in another router table. I resently got the big Porter-Cable 3 1/4 for the second table. Wow, that sucker is great and I should have done it long ago. It was on sale with a Woodpecker “quick router lift” (also a great purchase). I also got a Bosch 2 1/4 plunge/fixed combo and very happy with it. WHY so many? When in business … time is money. SO, my man, I DO INDEED RECOMMEND THE 3 1/4 PORTER-CABLE. That sucker will plow though anything. You can also slow things down if you need to. $$$ well spent !!! -- Odie, Confucius say, "He who laughs at one's self is BUTT of joke". |
294 days ago |
Woodcraft has the Triton 2 1/4 for $209.99 and the 3 1/4 for 214.99. You just get less goodies with the big guy, and the little guy has a winder mode so you can change bits and height above the table top. You should get both. Tell the Mrs. I said so (I may have to have you tell Pam about some tool I need in return). I’m sure this will work. MWAHAHAHAHA -- "Bordnerizing" perfectly good lumber for over a decade. |
294 days ago |
I’m new to the router stuff, so I’m not much help but from what I have read going big in your situation would be the way.. -- Brian's Table Top Toys http://home.mountaincable.net/~bgraham/ |
294 days ago |
i did a simalar question some time ago and peter oxly recomended the milwaukee 3 1/2 . i bought it and love it i use it for raised panels . it also has above the table hight adj. and varible speed which youll want for raised panels . so theres a new twist for your brain !! lol |
294 days ago |
Read the Subject line. PS Bought router table, (replaced with custom-job welded by my Dad from my plan (see my page) Incra fence and Unilift – a joy, and no variation in the RT deck. -- My Fear is when i die, my wife will sell my tools for what I TOLD her they cost |
294 days ago |
Thanks everybody. My choice is as clear as mud. <g> -- Charlie M. "Woodworking - patience = firewood" |
291 days ago |
After much self-debate, I ordered the 2 1/4 hp Triton kit from Amazon for $199 and free shipping. Maybe I’ll write my first review after I get it up and running. Thanks to all for the input! -- Charlie M. "Woodworking - patience = firewood" |
290 days ago |
I’m happy with my 7518 PC router in my router table. Soft start and variable speed. Good luck with your Triton. -- Gary, East TX -- The longest journey begins with a single step. |
290 days ago |
The 2 1/4 will work but for larger bits you will need to run the piece by the router multiple times until you get the required depth. -- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger” |
290 days ago |
Like Gary above, I have the PC 7518 and it is an awesome router for router table use. Best Wishes with your purchase! -- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure" |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1336 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1004 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
