Need help with cuts for a pyramid!
Forum topic by pashley posted 03-18-2017 09:49 PM 1067 views 1 time favorited 17 replies Add to Favorites Watch
View pashley's profile
pashley
1044 posts in 3959 days
03-18-2017 09:49 PM
Topic tags/keywords: pyramid
Hi,
I need help cutting a pyramid. I will be using ⅜” stock.
Here are the measurements of the pyramid when finished:
The rise is 2”, and it’s a square at 9 ⅜”
It will be mounted to a board.
My questions are: What are the blade angles for the miter joints, and the joint that will meet that board at the base?
Any other info is greatly welcome!
-- Have a blessed day! http://newmissionworkshop.com
17 replies so far
View 000's profile
000
2859 posts in 1141 days
#1 posted 03-19-2017 01:01 AM
47.4 miter
16.1 bevel
66.9 bevel at base
View 000's profile
000
#2 posted 03-19-2017 02:24 AM
Correction:
47.4 is the angle of the triangle piece, the slide saw would actually be set for 42.6
Pretty sure the bevel is still 16.1…(or if the scale starts at 90 then it would be 73.9)
19635 posts in 2098 days
#3 posted 03-19-2017 02:41 AM
By my calculation, it’s a 23.1° angle of cut. You would have to stand your pieces up against the fence to make that angle. You will need 6 layers to get 2”. I’m thinking you glue 3 together that are 9 3/8 square. Then cut them. You probably need to use a sacrificial fence. After you cut that one, measure the short square on top and glue three more layers together that are that size. Now cut them at the same angle. That should make a pyramid that when set on the other one else, makes a pyramid that is 2” tall.
View pontic's profile
pontic
664 posts in 850 days
#4 posted 03-19-2017 02:51 AM
9 3/8” base but the height of the actual triangle is more than 2” isn’t it? How do you get the true height? so you can calculate the angle. It’s been 30some years since I did any complex geometry.
So how did you arrive at those angles? What steps?
-- Illigitimii non carburundum sum
#5 posted 03-19-2017 02:56 AM
Rise over run. We know the rise is 2”. The run is half of the width at the base. I cheated and used a calculator to arrive at the angle, but otherwise it would have been tangents and cosines and the like. I too have forgotten how to use those.
View Lazyman's profile
Lazyman
2711 posts in 1629 days
#6 posted 03-19-2017 03:41 AM
If you drew that drawing in Sketchup, you can use the protractor tool to measure the angles.
View 000's profile
000
#7 posted 03-19-2017 03:53 AM
View waho6o9's profile
waho6o9
8539 posts in 2819 days
#8 posted 03-19-2017 04:08 AM
2 cool jbay, thanks
runswithscissors
2928 posts in 2267 days
#9 posted 03-19-2017 04:08 AM
So is this a solid block, or a hollow pyramid (with thin panels_?
#10 posted 03-19-2017 11:55 AM
Good point. I assumed solid because that’s the easiest way to make it. Now that you say that and I re read the post, I think it’s supposed to be thin panels. I’m no help with that.
pashley
#11 posted 03-19-2017 12:40 PM
Yes, this is ⅜” panels, glued up, not a solid block.
View htl's profile
htl
4329 posts in 1401 days
#12 posted 03-19-2017 03:11 PM
Would it come out nicer cut solid, then veneer it, just a thought.
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View squazo's profile
squazo
120 posts in 1887 days
#13 posted 03-21-2017 02:39 AM
here is how I would figure it out
I would cut an over sized triangle
then on a table draw a line that is 4 3/16” long and at 90 degrees to that the 2” line then
I would take a piece of scrap that is 3/8 thick and line it up on my lines and figure all the angles from there.
transfer the angles to the over sized triangle and blamo.
Im sure this was not much help but maybee you can get some ideas.
View 000's profile
000
#14 posted 03-25-2017 04:56 PM
pashley
#15 posted 03-25-2017 05:38 PM
Jbay,
Please except my apology; I sincerely appreciate your help and thank you very much!
