Titebond ?
« back to Joinery forum
Forum topic by alittleoff posted 03-18-2017 05:41 PM 759 views 0 times favorited 11 replies Add to Favorites Watch
View alittleoff's profile
alittleoff
541 posts in 1424 days
03-18-2017 05:41 PM
I’m jointing 2 pcs of oak wood. One pc. Has been finished with BLO and the other is raw wood. Will the joint hold using titebond2? Do I need to try an get the BLO off?
Thanks
11 replies so far
View mrbob's profile
mrbob
182 posts in 716 days
#1 posted 03-18-2017 05:53 PM
To be safe I would wipe the BLO area to be glued with Mineral Spirits, Naphtha or Acetone. Make sure it is dry b4 gluing.
View Bill White's profile
Bill White
5072 posts in 4108 days
#2 posted 03-18-2017 06:24 PM
+1 on the naptha. Dries quickly.
Bill
-- bill@magraphics.us
5095 posts in 2640 days
#3 posted 03-18-2017 08:55 PM
I guess I think the joint will fail, especially if the BLO has had a day or 2 to cure. It’s a film finish, albeit a very weak film….but I’d bet it’s enough to keep glue from bonding. But like I said, it’s just a guess.
View builtinbkyn's profile
builtinbkyn
2636 posts in 1088 days
#4 posted 03-18-2017 09:55 PM
Why not sand the area that will be bonded? It doesn’t have to be aggressive sanding. Just enough to break the surface. Then wipe it down as suggested.
-- Bill, Yo!......in Brooklyn & Steel City :)
View MT_Stringer's profile
MT_Stringer
3175 posts in 3378 days
#5 posted 03-18-2017 10:03 PM
If you are jointing two edges, what difference does it make. The wood will be bare on both edges.
mrbob
#6 posted 03-19-2017 12:42 AM
Just as suggested here glue and clamp over night within temp ranges and you will be fine.
View ArtMann's profile
ArtMann
1081 posts in 963 days
#7 posted 03-19-2017 02:49 AM
No glue is going to be as reliable when you are sticking it to a finish material rather than wood. My opinion is that BLO would make a worse surface than something like polyurethane or lacquer, because it doesn’t harden and provide a tough surface. If I were forced to try to glue BLO contaminated surfaces, I would use polyurethane. It sticks to some other materials when Titebond won’t.
View jacww's profile
jacww
24 posts in 1155 days
#8 posted 03-19-2017 12:07 PM
The Titebond site FAQ says “Most of our glues are designed to bond bare wood.”
A Titebond product manager recently spoke at the Woodworkers Guild I am a member of. He said that the wood glues bond to the wood fibers. So trying to remove the BLO makes sense.
Titebond FAQ page: http://www.titebond.com/frequently_asked_questions.aspx
TonyC
alittleoff
#9 posted 03-19-2017 12:44 PM
Im
Why not sand the area that will be bonded? It doesn t have to be aggressive sanding. Just enough to break the surface. Then wipe it down as suggested.
- builtinbkyn
I’m definitely going to sand the part of the wood before I glue it, I’d be stupid not to. But I don’t know how deep the BLO has gone in the wood. It has been sitting for about a month and has dried All its going to. I’ve figured out a way to use four screws without it looking to bad. Maybe with the glue and the screws it will hold. I learned a lesson about getting ahead of myself trying to finish the wood before it’s ready. Thanks for the help.
Gerald.
View htl's profile
htl
4111 posts in 1306 days
#10 posted 03-19-2017 03:03 PM
I had no idea what was being talked about so here’s some help.
BLO????
-- An Index Of My Model making Blogs here on Lumber Jocks.. http://lumberjocks.com/htl/blog/116729
View pontic's profile
pontic
634 posts in 756 days
#11 posted 03-19-2017 03:39 PM
Do you have a jointer,or a hand plane? I would use that before sanding. Plane down to the bare wood fibers. BLO doesn’t penetrate that far. Sanding does drive some of the BLO coated saw dust into the wood.
-- Illigitimii non carburundum sum
