Stanley 80 Cabinet Scraper?
Forum topic by Chris_T posted 10-15-2010 10:55 PM 7080 views 1 time favorited 12 replies Add to Favorites Watch
View Chris_T's profile
Chris_T
94 posts in 2758 days
10-15-2010 10:55 PM
I’m thinking about buying a old stanley 80 cabinet scraper to use in my shop. This will be my first scraper so I have a few questions. Do they take blades, if so, being that they are so old where can they be bought? Do these work better than standard scrapers? Also is there anything I should watch out for when buying one on ebay? I want the real deal not something fake.
12 replies so far
View cabmaker's profile
cabmaker
1720 posts in 2773 days
#1 posted 10-15-2010 11:24 PM
Your in luck, the #80 is readily available. E-bay is a source. Thay are pretty straight forward. I use one often. Actually my best results have been with the one I keep a sheffield hand scraper card in. If you like to drop things alot the 80m might be a consideration as it will not break when dropped. sharpening and burnishing the blade is key. (DID I SAY KEY ?) You l l like it. JB
cabmaker
#2 posted 10-15-2010 11:26 PM
Almost forgot, yes blades are still available but the ones I have seen in the last 20 yrs are a lot shorter than orig. That is the only reason I began using a card scraper in them. Good luck
View docholladay's profile
docholladay
1287 posts in 3023 days
#3 posted 10-15-2010 11:47 PM
I read a blog recently on one of the woodworking magazine websites (I think it was Fine Woodworking). Anywya, the gist of the blog was that the No. 80 was so readily available because they sold more of them than any of the others. The author speculated that the reason so many were sold was because it worked so well and was also very simple and easy to setup and adjust. I will give a big DITTO to that. I bought one for about $10 on Ebay. However, mine didn’t have the correct blade. I went searching for a blade. They are readily available and they aren’t very expensive. However, I decided to get creative. I had an old handsaw that was worn well beyond being useful. From the blade of that handsaw, I cut out a piece the appropriate size. I then ground a 45 degree bevel on 2 opposite edges, honed and polished those edges, then turned a hook on it. Bingo. For a total of about $20 (including shipping), I had the best scraper I have ever used. It works great.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View Fencer257's profile
Fencer257
15 posts in 2753 days
#4 posted 10-16-2010 01:13 AM
I prefer a 12 1/2 but the 80 works very well also. I also cut blades for both scrapers out of old saw plates. Once you start scraping you won;t go back to sandpaper.
View swirt's profile
swirt
2640 posts in 2936 days
#5 posted 10-16-2010 04:07 AM
I think this is the blog post doc was talking about.
http://blog.woodworking-magazine.com/blog/Cheap+Thrills+The+No+80+Cabinet+Scraper.aspx
I think I paid $15 for mine at an antique shop. My blade has about run its course though… not much left to it. Will probably get a Hock blade to put in it.
View MickeyD's profile
MickeyD
130 posts in 3491 days
#6 posted 10-16-2010 04:21 AM
There is a mention of it at the Woodworking in America blog at Popular Woodworking.
-- -Willing to try
TopamaxSurvivor
18246 posts in 3640 days
#7 posted 10-17-2010 03:20 AM
I have one but haven’t gotten to it yet. Keep the tips coming boys ;-))
View TechRedneck's profile
TechRedneck
768 posts in 2821 days
#8 posted 11-28-2011 11:36 PM
Been lurking for a while, I don’t do the ebay thing much however this weekend I was thinking I may like to get a #80 scraper for some larger panels of figured wood.
Anybody have luck with these? I guess I could go on fleabay but don’t know the difference between a good one or one made in Mexico or China in the Stanley line.
Tools for working Wood has the Kuntz but I have never used a Kuntz.
I noticed that WoodRiver has one, but the reviews stated they needed some work.
the #4 smoother works pretty good however no matter how I tune it on figured woods, I still get a little tear out. Could be technique but the hand scraper can get old (and hot) and tire the hands on larger panels. I had to get a project finished this weekend and had to ‘drop back and punt” to the sander because of some tear out.
suggestions?
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View Bertha's profile
Bertha
13521 posts in 2657 days
#9 posted 11-28-2011 11:44 PM
I love my 80. You can buy replacement irons but you shouldn’t have to. The iron that comes in your plane can be reground and reburnished.
@Tech, the vintage Stanley #80 can be had for very little. The Sweetheart era ones have robust irons. It’s paramount that when you shape the iron, you get it absolutely 90 degrees to the sides. Burnishing was a learning curve for me. Once I figured that out, my 80 will tackle anything.
Smitty_Cabinetshop
15280 posts in 2583 days
#10 posted 11-29-2011 12:00 AM
“Ditto” on Bertha’s last post re: burnishing being the biggest learning curve. The tool itself is, literally, foolproof. Drop the blade in while the tool is on a hard, flat surface. Tighten two thumbscrews to hold the blade. Turn the center thumbscrew as much or as little as you want to get ‘action’ below the sole. Scrape.
Bertha
#11 posted 11-29-2011 12:03 AM
^before I forget, Ron Hock’s got a burnisher for $15.00 and it’s a really nice one. There’s a minimum $10 shipping, so if you want one, wait until you’re ordering some irons.
TechRedneck
#12 posted 11-29-2011 03:31 AM
Ok. Thanks for the replies. eBay is all over the place on these. Looks like avg is around $40. Vreitas has one for $65 with some “improvements”. Part of me is saying…..”just spend the extra $25 on something that won’t take a lot to prep and has the quality. Now if I can find one for $10 that’s another story.
