Borshield never dries
Forum topic by Carloz posted 03-16-2017 05:30 AM 800 views 0 times favorited 9 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 648 days
03-16-2017 05:30 AM
It took me some time to remove dark spots on my table saw, which wax failed to prevent.
This time I used Boeshield T9. The instructions specifically mention table saws and I followed what is written there. However it has been 3 days and the stuff is still wet as if i just applied it. The temperature outside as 75F. What do I do wrong?
9 replies so far
MrUnix
6830 posts in 2255 days
#1 posted 03-16-2017 05:35 AM
Boeshield T9 is nothing more than really expensive paraffin wax dissolved in mineral spirits with a little bit of mineral oil thrown in. Most likely, it’s the mineral oil that is not evaporating off. Did you spray it on then wipe off the excess? BTW: Johnsons paste wax is essentially the same stuff (paraffin + some other waxes dissolved in Naptha) except for the mineral oil.
View DirtyMike's profile
DirtyMike
637 posts in 958 days
#2 posted 03-16-2017 05:42 AM
I am thankful for Johnson and Johnson.
View HokieKen's profile
HokieKen
5679 posts in 1195 days
#3 posted 03-16-2017 11:20 AM
I’ve used the Boeshield and didn’t see that it was worth they extra $. It doesn’t dry like paste wax, you spray it on and wipe off the excess. I thought it worked as well as, but no better than, paste wax. Only advantage I saw was that it was easier to apply. Johnson’s paste wax is what I use now for all my CI tables.
-- Kenny, SW VA, Go Hokies!!!
View rwe2156's profile
rwe2156
3003 posts in 1537 days
#4 posted 03-16-2017 03:19 PM
You have to leave it on for a few minutes then wipe it off.
The apply a second coat .
View DalyArcher's profile
DalyArcher
115 posts in 1176 days
#5 posted 03-16-2017 05:11 PM
I’m a fan of Johnsons paste wax as well.
View Manitario's profile
Manitario
2630 posts in 2939 days
#6 posted 03-16-2017 05:50 PM
I’ve had the same problem with Boeshield. Not a fan.
Carloz
#7 posted 03-16-2017 08:26 PM
I m a fan of Johnsons paste wax as well.
- DalyArcher
I was too before the cast iron top corroded in one week when I was away from home. Granted it was raining outside and the table corroded randomly. More on one of the wings than on the main table near the blade where I would expect it to wear through faster.
On the bright note t-9 Appeared to be far the best lubricant for a bicycle chain. The specialized stuff in bicycle shops is pretty expensive either so no throwing my T-9 into the trashcan and risking wrath from trash removal people.
View HorizontalMike's profile
HorizontalMike
7769 posts in 2970 days
#8 posted 03-16-2017 08:42 PM
The best way to apply JPW is to use a piece of 3-0 or 4-0 steel wool. The steel wool will work on lifting the surface rust, all while you are applying the JPW. Also, if you are having a hard time buffing JPW off, because you left it overnight, too long, too cold in shop, etc., re-applying with the steel wool makes it easy.
FWIW, I think I am still on my 2nd can of Johnson’s Paste Wax and it is STILL 1/2 full, even after 7 years of WW-ing. I guess at the current price of this stuff, I have probably spent 10-buck$ on this stuff, or about $1.43/year. I use most of it in the Texas Summers, when I drip sweat constantly if I am not directly in the path of a fan (I have6 or 7 in the shop). No AC but I do keep the air moving… ;-)
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2166 days
#9 posted 03-16-2017 10:47 PM
Along with bicycle chains, T-9 is also fantastic on r/v screw jacks and slide outs, as well as marine and aviation corrosion protection as was it’s original use. I think the 30+% non-hazardous part that doesn’t need to be identified on the MSDS is actually a bit more than wax, and the devil is in the proportions and details.
That said, I greatly prefer paste wax, Topcote, or CRC 3-36 on my machine tables and fences over T-9. In my experience, Trewax, Minwax, Liberon, or Goddards work just as well as Johnson, as long as you avoid tinted / colored versions, so whatever is easy to get locally is fine.
I get 3-36 locally cheap, so I use it a lot. It’s a also very good for removing built-up wax from metal surfaces.
I’ve had several occasions where machines got “hosed down”, an upper floor tub issued had my DJ-20 getting dripped on for a week, and my Sawstop ICS was the recipient of a steady stream of condensate at random times from a sweating mini-split a/c line. At the time, the only real protectant was a not so fresh application of 3-36, and nothing rusted, so I’m a believer in the stuff.
Avoid Briwax, as many versions are not your average paste wax.
