Can I Add Water to Water-Based Wood Fillers to Thin Them?
Forum topic by kanihoncho posted 10-14-2010 05:34 PM 17569 views 0 times favorited 10 replies Add to Favorites Watch
View kanihoncho's profile
kanihoncho
56 posts in 3095 days
10-14-2010 05:34 PM
I’m using elmers wood putty (large container) and it is starting to get a bit thick. Thanks.
10 replies so far
16275 posts in 4240 days
#1 posted 10-14-2010 06:39 PM
Probably. It may take a little experimentation to get something workable.
View Bearpie's profile
Bearpie
2601 posts in 3040 days
#2 posted 10-14-2010 06:43 PM
Won’t hurt to take a small sample and experiment with it. Let it sit for a couple of days and try gluing a scrap piece and seeing how strong the bond is before doing the full container. While buying in bulk is cheaper this is sometimes the result! Better to buy smaller quantities than having it go to waste or become unusable unless you have a large project coming up.
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
View Builder_Bob's profile
Builder_Bob
161 posts in 3081 days
#3 posted 10-14-2010 06:59 PM
I do that. Just a few drops and mix it in well. It completely rejuvenates the wood putty, just like new.
-- "The unexpected, when it happens, generally happens when you least expect it."
View SnowyRiver's profile
SnowyRiver
51457 posts in 3502 days
#4 posted 10-14-2010 08:04 PM
I agree with everyone…I do this too.
-- Wayne - Plymouth MN
View KayBee's profile
KayBee
1083 posts in 3268 days
#5 posted 10-14-2010 08:53 PM
Stuff with the orange lid-yep, just like everyone said. No difference in working of finishing after thinned out either.
-- Karen - a little bit of stupid goes a long way
View Rick's profile
Rick
9698 posts in 3055 days
#6 posted 10-14-2010 10:48 PM
Yes you can as everyone above has said. Add a Little at a time and Mix Well.
TIP: If you’re Edge or End nailing something with a Line of nails then filling them after countersinking…then you get fed up sanding it down and getting the powder into the Wood grain try this.
BEFORE nailing, run a strip of Masking or Painters Tape along the edge you’re going to nail. Nail, Countersink, Fill, Sand flush if necessary…then Remove the Tape. WALLA! Nice clean piece of wood.
The “Litle Voices” told me how to do that. ....LOL… Wait another mesagecoming throuh…WHAT!!!
Gotta Go: Rick
-- LIFE is what happens when you're planning on doing Other Things!
View Abbott's profile
Abbott
2570 posts in 3326 days
#7 posted 10-14-2010 10:52 PM
Those tubs of Elmer’s wood filler are a pretty good product. However I have never been able to get through a full tub or even half of a tub before it dried out. I am back to the tubes when I need wood filler.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View Popsnsons's profile
Popsnsons
387 posts in 3004 days
#8 posted 10-14-2010 11:04 PM
I usually use the sawdust from the same project with a dab of wood glue as a filler. If you sand it before it cures you should have a glueless top surface as the sanding will fill in over the outer surface and can usually hide the repair very well.
-- Pops ~ In So Cal...
View BTKS's profile
BTKS
1986 posts in 3486 days
#9 posted 10-16-2010 06:15 AM
I do what Popsnsons does. You get a perfect color match and its really cheap!
Rick: Thanks for the tape tip!
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View Timberwolf323's profile
Timberwolf323
69 posts in 865 days
#10 posted 02-08-2016 06:31 AM
And I thought I was the only one that hoarded fine sawdust from the bags of my ROS extractor. My wife thinks I’m odd for keeping sawdust. But it makes a great pore filler filler too!
