Forum topic by linesoflux | posted 10-13-2010 08:10 PM | 1623 views | 0 times favorited | 3 replies | ![]() |
I just replaced an arbor and bearings on a 20yr old craftsman tablesaw. I need to install a woodruff key in the new arbor (and a new pulley) but it seems a little too big to fit in the slot. In fact I had to heat the old one somewhat with a torch to get it out (of the old arbor). It won’t fit back in either (unless I re-heat it again I assume). Is the key supposed to fit so tight that you need to heat the arbor to remove and/or install it? Any special process I’m missing? Any help would be appreciated! |
