I recently bought a Bosch ROS65VC-6 and have been attempting to use it with my Ridgid shop vac.
The vacuum overpowers the sander, causing it to move uncontrollably unless part of the pad is off the work surface. It's also leaving lots of swirl marks, but only when used in conjunction with the vacuum.
On the Bosch, there's even a gap that's exposed where the tool meets the hose, I presume to drop the pressure a bit. This is fully exposed, and it's still a problem.
Do I need a less powerful vac or what's the solution here?
