Table legs to Table top HELP
« back to Joinery forum
Forum topic by steliart posted 03-14-2017 02:06 PM 693 views 0 times favorited 14 replies Add to Favorites Watch
View steliart's profile
steliart
2851 posts in 2890 days
03-14-2017 02:06 PM
Topic tags/keywords: table legs table top joining modern question threaded insert internal hex bolt
I’ve been building table with 20 degrees angle legs and I was planning to attach the legs with internal hex flat head bolts through the top and threaded inserts on the legs. Unfortunately the red hard wood (massaranduba) I used breaks very badly when I try to insert a threaded insert so I gave up that idea.
I am looking from some advise/ideas how can I attach those legs.
Please look on the two sketches to have an idea of what I am trying to do.
Thank you.
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of inventions !!!
14 replies so far
View ChefHDAN's profile
ChefHDAN
1193 posts in 3051 days
#1 posted 03-14-2017 02:21 PM
Sliding dovetail perhaps? Check out how this top is attached, it’s a beautiful method. https://www.youtube.com/watch?v=x51zMg7roIs
View tyvekboy's profile
tyvekboy
1823 posts in 3215 days
#2 posted 03-14-2017 02:30 PM
Another option is to drill a 3/4 inch hole about 1 inch deep and glue or epoxy a hardwood dowel in the hole. Then you can drill and insert the threaded insert in that softer wood.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
steliart
#3 posted 03-14-2017 02:34 PM
ChefHDAN thank you for the link and for taking the time to answer me…!!!
Yes it’s a nice method but it won’t work for me at this point as it’s a folding leaf table and legs are attached on the leafs and the dovetail cut will show when folded… but it is one strong way of doing it… even though I might consider it.
Thanx
steliart
#4 posted 03-14-2017 02:36 PM
Tyvekboy… thank you that is a good possibility… nice advise !!!
View HokieKen's profile
HokieKen
7127 posts in 1340 days
#5 posted 03-14-2017 04:54 PM
Another option would be to use tee-nuts that you install with brads (not the barbed ones) instead of the threaded inserts.
-- Kenny, SW VA, Go Hokies!!!
steliart
#6 posted 03-14-2017 05:14 PM
HokieKen thank you for the idea but the only ones I can get are the barbed ones, but I may try to cut the barbed points and drill 3 holes, that might work … Thank you for the advise !!!
View andyboy's profile
andyboy
565 posts in 3475 days
#7 posted 03-14-2017 07:05 PM
Have you got an actual picture of your job?
-- Andy Halewoodworker. You can't finish if you don't finish. So finish it, because finish is everything.
steliart
#8 posted 03-14-2017 07:57 PM
andyboy… just a mobile snapshot of the top not the legs right now, that’s why I put the sketches up Andy :)
View jerryminer's profile
jerryminer
944 posts in 1643 days
#9 posted 03-14-2017 09:55 PM
Drill an over-sized hole and epoxy in your threaded inserts?
To keep the internal threads clean, coat a bolt with Vaseline and thread it into the insert while the epoxy sets.
View bondogaposis's profile
bondogaposis
5091 posts in 2553 days
#10 posted 03-14-2017 10:52 PM
I would use mortise and tenons if it were my design. But since you have likely already cut the legs to length, it is too late for tenons. In this situation I would opt for loose tenons.
-- Bondo Gaposis
steliart
#11 posted 03-14-2017 11:19 PM
jerryminer thanks for the advise that is also a possibility like the t-nuts epoxy and screws
steliart
#12 posted 03-14-2017 11:26 PM
bondogaposis wanted a mechanical fastening method as the legs are not stationed but attached to the drop leaf sides thus folding with them, thats why didnt use mortise and tenons although I used them to connect the triangular top part of the leg… thank you :)
View papadan's profile
papadan
3584 posts in 3570 days
#13 posted 03-14-2017 11:32 PM
Why do you need to bolt the legs on?
steliart
#14 posted 03-14-2017 11:38 PM
papadan because are movable folding leaf legs and 1 inch thick only so i believe a through the top fastening will be stronger
