How to attach torsion box top to base???
Forum topic by Walker posted 03-14-2017 01:47 AM 982 views 0 times favorited 8 replies Add to Favorites Watch
View Walker's profile
Walker
146 posts in 618 days
03-14-2017 01:47 AM
So I’m done with the base for my workbench. I’m going to build a torsion box top for it with 1/2” MDF skins. My question is how to attach the top to the base? Most of the online plans and websites seem to gloss over or ignore this part. Would L-brackets or figure 8 clips be sufficient or do I need to devise something more heavy duty?
-- ~Walker
8 replies so far
View jerryminer's profile
jerryminer
944 posts in 1587 days
#1 posted 03-14-2017 02:07 AM
L brackets or figure-8’s would work fine, as would screws through cleats attached to the base.
View Andre's profile
Andre
2063 posts in 1952 days
#2 posted 03-14-2017 02:09 AM
I would attach a full width block on either end to act like a Mortise and tenon on the inside of your base frame?
You could glue/screw it onto the bottom panel before assembly, then the top could be removable.
View clin's profile
clin
929 posts in 1142 days
#3 posted 03-14-2017 02:58 AM
Pocket screws in your base up into the top.
-- Clin
Walker
#4 posted 03-14-2017 03:25 AM
Would pocket screws be essentially the same strength as doing cleats? Seems like it would be about the same, with pocket screws being less work. The base has little to no movement and I’d like for the top to not add any. I don’t need it the top to be removable, as it will only be 32” deep. It will fit through my doorways if I ever relocate. Maybe a cleat/block on either end and pocket screws throughout the rest would be quite sturdy?
Btw Clin, the base came out great. My over-complicated design made for an over-complicated (patience testing) build, but it worked as intended. I toned it down following your and others advice. It seems super sturdy and is as flat and level as I could have hoped for.
-- ~Walker
View newwoodbutcher's profile
newwoodbutcher
762 posts in 2996 days
#5 posted 03-14-2017 06:08 AM
I agree with Andre. Even if the blocks only receive screws for the figure eights. I would probably not mortise though for a piece of shop furniture. I’d probably go with pocket screws and interior blocks.
-- Ken
5095 posts in 2639 days
#6 posted 03-14-2017 11:43 AM
I don’t think I would fasten it to the frame. Instead I would just put 4 cleats on the underside of the top that would sit on 4 of those pockets you have. The weight of the top should hold it down, and the cleats keep it from sliding off the frame.
View clin's profile
clin
#7 posted 03-16-2017 10:58 PM
Would pocket screws be essentially the same strength as doing cleats? Seems like it would be about the same, with pocket screws being less work. The base has little to no movement and I d like for the top to not add any. I don t need it the top to be removable, as it will only be 32” deep. It will fit through my doorways if I ever relocate. Maybe a cleat/block on either end and pocket screws throughout the rest would be quite sturdy?
- Walker
If cleats are only screwed on, there is no advantage to them. But they could of course also be glued. But just pocket screws are likely fine. And if the day comes, you find those working loose. You could glue and screw cleats on.
Solve the problem if you ever have it. But, lets keep in mind that adding some cleats is super simple.
I certainly would use a good number of screws. Like every 8” or so. It is overkill in a sense. Any one screw is probably good for 100+ lbs of shear. But if you are putting a lot of side loads on the top, like hand planing. You want to make sure the screws don’t wear down the wood and loosen over time.
-- Clin
View jbay's profile
jbay
2677 posts in 1045 days
#8 posted 03-16-2017 11:38 PM
L Brackets are plenty..
