installing house numbers
Forum topic by BobD posted 10-12-2010 03:54 PM 1928 views 0 times favorited 2 replies Add to Favorites Watch
View BobD's profile
BobD
52 posts in 3652 days
10-12-2010 03:54 PM
I bought some fancy house numbers that don’t have screws to attach them to the wall of my house. Instead there are 1/2” long tapered legs attached to the back of each number. Do you drill a snug fitted hole in the stucco and epoxy the leg into the hole, or is there a better way?
-- Bob, San Diego
2 replies so far
16281 posts in 4458 days
#1 posted 10-12-2010 04:03 PM
I’ve never seen that exact setup, but my guess would be that because the studs are tapered, it’s meant to be a friction fit. Theoretically, you could drill a snug hole, and tap the numbers in with a rubber mallet. Adding some epoxy will make it more permanent, but also create more problems if you ever want to remove the numbers.
View PurpLev's profile
PurpLev
8548 posts in 3888 days
#2 posted 10-12-2010 04:26 PM
you could probably put a dab of silicone to give it a bit of a better hold, silicone is slightly flexible and will not create stressed in the stuco, also it CAN be pulled if you ever really want to – not that I forsee the house being renumbered or anything like that … but just in case.
