Pre-Catalyzed Lacquer Recoat
Forum topic by Fax posted 03-12-2017 03:57 PM 547 views 0 times favorited 2 replies Add to Favorites Watch
View Fax's profile
Fax
62 posts in 696 days
03-12-2017 03:57 PM
Using spray can, I applied two coats of pre-catalyzed lacquer on a coffee table, at 1/2 hour interval.
Because I ran out of lacquer, I could not finish with a third coat.
Is it ok to apply another coat after 12 hours or two days later; until I get some more pre-cat. lacquer?
Will this cause adhesion problems or wrinkle?
Thank you very much for your help!
Julian
-- Julian Paul Jones
2 replies so far
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
#1 posted 03-12-2017 04:09 PM
Assuming everything is still clean, it will work fine.
View Fax's profile
Fax
#2 posted 03-12-2017 04:48 PM
Thank you very much for your answer!
I appreciate it very much!
The spray can feels a bit light and I am afraid to start another coat.
I will get more tomorrow evening from Mohawk.
