Well I finally purchased my compressor
Forum topic by Raymond posted 950 days ago 472 views 0 times favorited 4 replies Add to Favorites Watch
View Raymond's profile
Raymond
665 posts in 1892 days
950 days ago
I finally purchased my compressor. I went with the Puma, looks like a good unit. Review to follow. Howerver there is no shut off valve after the regulator, just a quick disconnect. All my other compressors had this shut off valve. I am thinking of removing the quick disconnect and addeding the valve then replace the qucik disconnect. Anyone else have a compresspor with out the shut off valve?
-- Ray
Raymond
#1 posted 950 days ago
Thanks Shopguryl, I think I will put one on. I can’t imagine why they do not come with one already installed.
-- Ray
View Gregn's profile
Gregn
1643 posts in 1149 days
#2 posted 948 days ago
Congrats on the Puma as well. What size did you get? Mine is the 60 gal. and had the valve on it. A suggestion that I did with mine was to remove the pit cock valve on the bottom for draining and replace with a Ball cock valve for easier draining. I put a elbow and then a nipple then the valve so all I had to do was to reach down to drain the tank.
View TheShat's profile
TheShat
8 posts in 948 days
#3 posted 948 days ago
Add the shut off, its very worthwhile
Raymond
#4 posted 948 days ago
Thanks for the suggestion on the drain valve, I got the 20 gallon 5 HP, it’s been 2 days now and no leaks still holding at 135 psi. Review to follow as soon as I get some pictures.
-- Ray
