Couple of finishing questions
Forum topic by JCamp posted 03-11-2017 11:08 PM 518 views 0 times favorited 5 replies Add to Favorites Watch
View JCamp's profile
JCamp
712 posts in 602 days
03-11-2017 11:08 PM
Topic tags/keywords: finishing
This weekend I’ve been able to tackle a couple small projects but now they need finished…
1st project – I hav a 16ft long work bench I put 1/4inch plywood on top of it but I’m not sure how to finish it. It’ll b mainly used for assembly and staining of wood projects I thought about poly but not sure it’ll hold up
2nd project – I made my wife a small light duty cutting board. What should I finish it in? I thought about BLO but seems lik I’ve read that that’s not a good thing to do (at least not the store bought kind)
Thanks in advance
-- Whatsoever thy hand findeth to do, do it with all thy might
5 replies so far
View bondogaposis's profile
bondogaposis
4822 posts in 2403 days
#1 posted 03-11-2017 11:55 PM
Mineral oil on the cutting board. Oil base poly is the most durable finish, it will be fine for a workbench.
-- Bondo Gaposis
View ralbuck's profile
ralbuck
4690 posts in 2318 days
#2 posted 03-12-2017 12:32 AM
If the workbench is going to get very hard usage; get sheet metal thin gauge like is used for roofig flashing and buy a piece wide & long enough to cover it in one chunk.
When i turned wrenches ; we had that on the shop bench and it took a terrible abuse.
Or consider the plywood as expendable and put it on to be easily changed.
-- Wood rescue is good for the environment and me! just rjR
View Lazyman's profile
Lazyman
2163 posts in 1439 days
#3 posted 03-12-2017 03:22 AM
Melamine is good for assembly and finishing because most glues can easily be scraped off and drips of finish can usually be scraped off as well. It definitely offends my wood working senses but it sure is nice and easy to clean off.
JCamp
#4 posted 03-21-2017 01:56 PM
I visited my local ACE hardware yesterday. They do not sell mineral oil but they do have Lemon oil. Can I use that for my cutting board instead of mineral oil? I found and old LJ thread that says Lemon oil is just scented mineral oil…...
Lazyman
#5 posted 03-21-2017 01:59 PM
You can buy mineral oil at any pharmacy or even Walmart. It is used as a laxative!
