Lighted Crux - How to fit diffuser?
Forum topic by BertFlores58 posted 10-11-2010 02:59 PM 964 views 0 times favorited 2 replies Add to Favorites Watch
View BertFlores58's profile
BertFlores58
1698 posts in 3070 days
10-11-2010 02:59 PM
Topic tags/keywords: tip question
I am still thinking of the possibility of constructing this Crux. Diffusers of different colors will be fitted in front and light (flourescent lamps) will be fitted. The side to the wood is not a problem however the one that will connect diffusers to each other will be difficult. Anybody can help me?
here is the design… (anyone who like in sketch up ) send me a pm and need your e-mail address)
Thanks for your help.
-- Bert
2 replies so far
View miserybob's profile
miserybob
88 posts in 3193 days
#1 posted 10-11-2010 04:12 PM
What is the diffusion material? If it’s glass, then lead came or copper foil would be an option. If it’s plastic, then that’s not gonna work.
BertFlores58
#2 posted 10-12-2010 03:49 AM
I am not using a glass. I am using diffuser that is probably fiberglass (it easily breaks not a real plastic or polycarbonate stuff) about 1/8 inch thick. The same material for ceiling flourescent lamps’ diffuser. Lead or aluminum comes into 1/4 groove and it is too loose. Thanks for the idea.. it maybe possible to fabricate from hardwood strips and instead of groove I might use 45 deg countersunk style… this will flash the diffuser end to end. Looks like this piece…
-- Bert
