Shave horse from white ash log
« back to Hand Tools forum
Forum topic by wflather posted 03-11-2017 10:12 PM 1117 views 2 times favorited 9 replies Add to Favorites Watch
View wflather's profile
wflather
33 posts in 1164 days
03-11-2017 10:12 PM
Topic tags/keywords: shave horse shavehorse ash shaving horse
Around our property, our ash trees are dying (thanks to the emerald ash borer).
I’ve wanted to make a shave horse for a long time, and this seemed like a good time to do so.
Built mostly with hand tools, with a little help from lathe and table saw.
Starting from this log:
First plank:
Pieces for legs and other parts:
Smoothing the planks with a scrub plane:
Then moving on with the smooth plane – Stanley #4 1/2:
Using adjustable bevel as auger guide for leg holes:
Table saw guide for rounding the legs since they were too large and unbalanced for my lathe:
Drying the leg tenons in a sand-filled crock pot. This shrinks the wood for a snug fit:
Some parts for the vise:
This shavehorse will have a hinged, adjustable stand-off for the vice:
Final assembly- vice parts; top and food rests were turned on a lathe:
Shavehorse being put to work:
9 replies so far
View diverlloyd's profile
diverlloyd
3017 posts in 1975 days
#1 posted 03-11-2017 11:35 PM
Very nice it’s good to see some ash that isn’t being turned into firewood.
View TungOil's profile
TungOil
1006 posts in 613 days
#2 posted 03-11-2017 11:57 PM
Great project!
I’m having the same problem with the ash borers. The ash trees in my yard are falling faster than I can deal with them. I had a guy with a wood miser come out and cut up 10 ash and a couple walnut trees that came down. Some of the ash is 16-20” wide. I now have a lifetime supply.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
wflather
#3 posted 03-12-2017 12:59 AM
I wish I had figured out how nice it was to work with sooner, now I too can’t harvest then fast enough. I should have some of the larger ones sawn into lumber. It sure steam bends well and I wonder if it will make good chair seats. Of course it does make good firewood.
View Dave Polaschek's profile
Dave Polaschek
2596 posts in 700 days
#4 posted 03-12-2017 11:00 AM
Nice! Now that you have a shave horse, you can also use ash for canes, legs for things, etc.
-- Dave - Minneapolis
View Tim's profile
Tim
3812 posts in 2079 days
#5 posted 03-12-2017 01:03 PM
Awesome project. From log to a shop tool you can use for even more. Did you scrub and smooth plane the bottom of the plank too? That’s some dedication. Love your adjustment mechanism too.
View Bill White's profile
Bill White
5048 posts in 4078 days
#6 posted 03-12-2017 02:13 PM
Very well done, and I’ve not seen the sand bucket method before. Heated the sand?
Bill
-- bill@magraphics.us
wflather
#7 posted 03-12-2017 04:12 PM
Bill White- yes the sand is hot, left the leg tenons in for a couple hours to drive out the moisture and shrink them. Sized them just a bit larger, maybe 1/16” or so too big. Once dry tweaked the fit with spokeshave and sandpaper. With glue and ambient moisture they swell and you get a really snug fit. As the plank continues to drive, the fit gets snugger.
Tim, I did smooth all surfaces with the #4.
View Karda's profile
Karda
1223 posts in 672 days
#8 posted 03-12-2017 05:38 PM
very nice bench
View mike02130's profile
mike02130
170 posts in 790 days
#9 posted 03-12-2017 09:26 PM
Beautiful and most respectable. I’m sure a lot of folks are humbled by the work.
It’s nice to see a post that isn’t some knuckle head question.
-- Google first, search forums second, ask questions later.
