What is the v-notch used for in this saw horse?
Forum topic by Jon_Banquer posted 10-10-2010 10:23 PM 2485 views 0 times favorited 8 replies Add to Favorites Watch
View Jon_Banquer's profile
Jon_Banquer
69 posts in 2714 days
10-10-2010 10:23 PM
Topic tags/keywords: question
http://tinyurl.com/2f2o8mw
The answer given is: “for supporting thin work while ripping, particularly notching.”
I would appreciate if someone could post an alternative explanation that hopefully I will be able to grasp because I cannot visualize the explanation given.
Thanks in advance,
-- Jon Banquer San Diego, CA CAD / CAM programmer, CNC Machinist
8 replies so far
View jusfine's profile
jusfine
2422 posts in 2831 days
#1 posted 10-10-2010 11:03 PM
If it was a thin strip, say 8” wide, you would project the work over the V in line with the sawhorse, and cut toward the point of the V, like shopgurl says, supporting the work on each side. The most force and chance to break a thin piece is where the teeth are contacting the work, so this provides required support.
Does that help?
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View John Ormsby's profile
John Ormsby
1283 posts in 3642 days
#2 posted 10-10-2010 11:08 PM
For securing round stock. For example: to cut a notch in the end of or rip round or small stock.
-- Oldworld, Fair Oaks, Ca
Jon_Banquer
#3 posted 10-10-2010 11:19 PM
Shopguryl and justfine would you both agree that what the V notch is actually providing is support and clearance and that this is not obtainable for thin work on a sawhorse without a V notch?
jusfine
#4 posted 10-10-2010 11:21 PM
I would agree, Jon.
TopamaxSurvivor
18193 posts in 3581 days
#5 posted 10-10-2010 11:42 PM
Sure would be handy for making a birds mouth cut on the end of a rafter if anyone cut rafters any more ;-))
View Dennisgrosen's profile
Dennisgrosen
10877 posts in 3021 days
#6 posted 10-10-2010 11:43 PM
Jon
have you ever made any scrollsaw work the old fasion way with a deep fret saw
if you have you wuold know its excacly the same concept there is talking about
the saw http://www.highlandwoodworking.com/eclipsedeepfretsaw-11-38deep.aspx
Dennis
3809 posts in 3927 days
#7 posted 10-10-2010 11:59 PM
If you have ever ripped a thin board like shiplap or the like with an 8 tooth hand saw you will see the advantage of having support at or near the area being cut. The saw must be pushed through the wood to creat the kerf and it chatters considerably on the back stroke making the board swivel and scoot around the end of the horse.
Sawing on one side or the other is a chore as the legs are in the way.
View Abbott's profile
Abbott
2570 posts in 3209 days
#8 posted 10-11-2010 01:06 AM
Yeah, that V notch looks handy for working with thin or small stock. It would work well for cutting some notches.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
