Box Hinges
Forum topic by Gooch posted 958 days ago 761 views 0 times favorited 7 replies Add to Favorites Watch
View Gooch's profile
Gooch
6 posts in 1058 days
958 days ago
Topic tags/keywords: question hinge box box hinge soss barrel hinge concealed hinge quadrant hinge
Hey Everyone,
Has anyone used SOSSĀ® Concealed Barrel Hinges when building boxes? I’ve been looking around for an affordable ‘invisible’ hinge and this seems to fit the bill, but I’d like to know your experiences prior to purchasing. I’ve also looked at quadrant hinges, but they’re a bit pricey.
Thanks,
Kevin
7 replies so far
14866 posts in 2391 days
#1 posted 958 days ago
I’ve been wanting to try these myself. It looks like the toughest part would be getting the holes perfectly aligned on base and lid.
If you want to try quadrant hinges, Lee Valley offers some that are reasonably priced and decent quality.
View zwwizard's profile
zwwizard
171 posts in 1882 days
#2 posted 958 days ago
I’ve used the hinges quite often. What I do is drill the back piece first before the top is put on. If the top is going to cover the sides. Plan your cut line ahead and drill pass it. If you drill to far you can put a plug in it,.
-- Richard http://www.PictureTrail.com/gallery/view?username=thewizz
View lilredweldingrod's profile
lilredweldingrod
2498 posts in 1279 days
#3 posted 958 days ago
I just tried my first ones. The alignment is easy if you use a fence on the DP. BUT if you put them in the middle of the board, when you open the lid, they pull out. You have to put then right at the edge or 45 the box and lid on the back side. And that looks like crap. Want mine?
View richgreer's profile
richgreer
4474 posts in 1247 days
#4 posted 958 days ago
I’ve used them once many years ago. In my case, I discovered that once the barrels set into the holes they are not coming out again and you cannot twist them in the hole either (at least I could not). That means you have to put them into the hole the right way the first time.
Gooch
#5 posted 957 days ago
Thanks for the advice guys. I think I’ll go ahead and order some of these. Any thoughts on installing these hinges in the absence of a drill press???
View papaG's profile
papaG
4 posts in 1271 days
#6 posted 931 days ago
Use a ‘DOWEL POINT SET’.
Before cutting the 45 bevels, drill lid, use the point set to mark the location on your base.
View RalphBarker's profile
RalphBarker
80 posts in 942 days
#7 posted 931 days ago
There’s always the re-purposed leather belt and cut nail approach. For larger chests, the wider belts from dead pirates work well. ;-)
