powermatic 63 fence upgrade
Forum topic by craigmcourtney posted 03-10-2017 12:11 PM 597 views 0 times favorited 5 replies Add to Favorites Watch
View craigmcourtney's profile
craigmcourtney
2 posts in 592 days
03-10-2017 12:11 PM
hello everyone; first post here.
I have an older powermatic 63 with an original 36”(I think?) vega fence. I’m not wired for 220v in my garage, and I’d like to have a wider cutting surface + outfeed table to cut full sheet. With these constraints, my best option (I think) is to build a custom table for my PM 63 and purchase a 52” fence.
I’d really like to upgrade to a beisemeyer-style 52” fence rather than the Vega. would a fence designed for a PM 66 cabinet saw fit onto the PM 63? I don’t want to order something that would require new holes for bolts to be tapped.
thank you in advance.
5 replies so far
View HokieKen's profile
HokieKen
6298 posts in 1287 days
#1 posted 03-10-2017 06:29 PM
I have the PM63 and I love the Vega fence. No idea why you want to switch it out with a whole new fence. All you really need is the longer rails for the Vega fence.
That being said though, if you want to put a PM66 fence on it, I’m 99% sure all PMs have the same bolt pattern. Someone with a PM 66 should be able to take the measurements and verify for you though.
Welcome to LJs!
-- Kenny, SW VA, Go Hokies!!!
View TheGreatJon's profile
TheGreatJon
339 posts in 1382 days
#2 posted 03-10-2017 07:38 PM
I have a 48” beismeyer with the long rails on my PM72. It may or may not have the same spacing as the fences that were put on the 66s. I can measure the bolt spacing tonight if no one else gets it to you before then.
I hope you have a good sized space for your table saw. The 52” rails/extension table take up a ton of room. Also, I’d add that even with the table top, I will sometimes clamp a makeshift fence onto the sheet and then just break it down with a circular saw. I can cut a 4’x8’ sheet down the middle on my table saw, but depending on the cut it is sometimes just easier to do it with the circular saw.
-- This is not the signature line you are looking for.
View knotscott's profile
knotscott
8129 posts in 3524 days
#3 posted 03-10-2017 08:16 PM
I’d just call Vega and ask what it’d cost to get longer rails. It’s a good fence. I like the old style Biese a lot too, but don’t see it being worth a hefty premium over the Vega with longer rails unless there’s some issue with your Vega.
9585 Bruce Rd. Decatur, IL 62526
Phone: (217) 963-2232
Fax: (217) 963-2246
email: remvega@aol.com
knotscott
#4 posted 03-12-2017 09:52 PM
Still there Craig?
craigmcourtney
2 posts in 592 days
#5 posted 03-15-2017 06:46 PM
hello, and thanks for the replies, everyone.
My apologies for such a slow reply. I’ll try to be more prompt later.
I’m not sure if my Vega system has a real issue; I just prefer the Biese system. But, I’d rather spend less $ than more $, so I’ll just find the longer vega rails and be done with that.
and yes, I think I’ll have enough space for the setup.
Thanks everyone.
