How To Make Thomas The Train Track?
Forum topic by Pezman posted 959 days ago 7551 views 0 times favorited 8 replies Add to Favorites Watch
View Pezman's profile
Pezman
17 posts in 1453 days
959 days ago
Greetings!
I’m looking for advice on how to make some train track for my son. It seems that most of these track manufacturers are building to the same dimensions (Brio, Thomas The Train, etc). I cannot however figure out the best way to build track at home and am looking for advice from you.
What I’m thinking:
  • I’m assuming I should use white birch so it stands the test of time without breaking the bank. If you disagree, let me know.
  • I can’t really figure out how to make the track male / female connectors, should I just try with a scroll saw?
  • I don’t really know how to make those grooves on curved blocks since I can’t just do a rabbet cut there. I guess I need a small router bit.
What I found from searching:
I’m looking for any helpful links / advice on how to knock out a great volume of track for my son since buying new is expensive. I’m looking to make straight pieces, curved pieces, ideally ones that gain height, etc. Example of a retail kit: http://thomaswoodenrailway.hitshopusa.com/ttp/Thomas-Friends-Wooden-Railway-5-in-1-Track-Layout-Pack/cPath/10716/products_id/121255.html
Thanks in advance!
8 replies so far
View Peter Oxley's profile
Peter Oxley
1423 posts in 2047 days
#1 posted 958 days ago
Personally, I think I’d buy the router bit set. If you make 60 pieces of track, you’ve paid for the bits. And by the time you figure out how to make all those cuts with other bits/tools, I think you’ll wish you had the set.
That being said, the grooves could be made with a straight router bit and a pin-type edge guide (rather than a fence-type). The connectors could be made with a scroll saw if you lay them out carefully.
Just about any tight-grained hardwood should hold up okay. I have a source for inexpensive “brown maple,” so that would probably be my choice.
-- http://www.peteroxley.com -- http://north40studios.etsy.com --
View Jeff in Huntersville's profile
363 posts in 1366 days
#2 posted 958 days ago
The ones we bought for my son when he was younger were made of maple. I’d use hard or rock maple if you can get it but I don’t see why any hardwood would’nt be suitable as long as it’s knot or defect free and you’re paying attention to the grain. I’d also go ahead and buy the set. Once you get set up you might find you’re making some for friends or relatives or who knows even making some to make your money back?
View MrsN's profile
MrsN
917 posts in 1698 days
#3 posted 958 days ago
I was thinking of making wooden track sets last Christmas, but I decided against it. I came to the conclusion it was more work then I wanted to put into it. Between the material cost, bit costs, and time, buying the set was easier.
I also don’t have the space to keep a really large amount of track, so I would not have made enough to off-set the investment of bits and lumber.
When I was thinking about making them, I decided that it would be in my best interest to buy the track bits. I don’t have many good quality router bits on hand and would have needed to purchase some to make the tracks. If you are good at jigs and templates making a pattern to duplicate would simplify the process a lot.
I wasn’t sure if the connector router bits would be as useful. I had considered using the “dowel with ball” type connection, but the number of holes to drill and all the assembling might get old.
Straight tracks can be made by cutting shallow dados into stock, and making connections on a scroll saw. If you add some extra straight pieces it may be enough to boost store bought track packs.
-- ----- www.KNWoodworking.com ----- --
Pezman
#4 posted 957 days ago
Update: I went ahead and purchased 3 of the 4 bits online last night for $79 dollars @ Amazon. I’ll keep you posted once I start cutting with them.
I also posted about the activity table where these train tracks will live. http://lumberjocks.com/projects/38284
View Dan Lyke's profile
Dan Lyke
1367 posts in 2297 days
#5 posted 957 days ago
I used a 3/16” straight bit to do something similar, though I just cut a figure 8 with a cut-off side into some Baltic Birch.
I contemplated getting more dramatic, but couldn’t figure out a good way to do connectors either. Eventually I decided that if I was going to go forward I’d just do ‘em as dovetails.
And, yeah, I had the same track as DaveR when I was a kid, and my parents still have that track…
View AuroraWoodworks's profile
AuroraWoodworks
191 posts in 1295 days
#6 posted 956 days ago
For the connectors, I think the easiest way would be to make both ends of your track “female” and make a bunch of dogbone shaped connectors. Make the connectors from two pieces of vertical 3/8” dowel connected by a horizontal 3/16” dowel. These pieces will pose a choking hazard, so keep it away from kids under 3 (or whatever the law is).
I had a friend who made Brio track using 3/4” solid wood flooring strips. He didn’t mess around with cutting them into short pieces. He left them full length. He built some serious train layouts!
-- Tony - Anchorage, Alaska
View Mark Shymanski's profile
Mark Shymanski
3966 posts in 1885 days
#7 posted 956 days ago
I tried making some track for my son. I just drilled out the female part and then notched out the connector on the band saw. I made the male portion completely on the bandsaw. It’s a bit tricky but possible. Paul likes it because it is a great piece of track and his Dad made it :-). I routed out the track just using a 1/4 inch bit in my table router and set the fence to give me the proper ‘rail’ spacing. I used some maple I had left over it seems to work well.
On a side note the battery powered engines have different ground clearance than the manual ones and you have to shave the inside of rails to allow the engines to run around the track.
I looked at buying the router bits as well, but I can’t see making enough track to make it pay…yet :-)
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
View Crozier's profile
Crozier
1 post in 945 days
#8 posted 945 days ago
As AuroraWoodworks said before, the dogbone connectors work great, but can be swallowed by little kids. However, by making one half of your track with the female connector and then boring a 3/16” hole in the opposite end of the track you can take one vertical half inch long 3/8” dowel and then use a short piece of 3/16” dowel to glue it to your track to create the male. Much easier to fabricate than delicately cutting each piece individually. With a couple of simple jigs you can fire through as many as you need in no time at all.
